Old 07-02-2010, 02:38 PM
levelaudio levelaudio is offline
Default fine adjustment of breakpoints not working
When holding down the command key and moving an automation breakpoint, it never moves it in any finer increment than it is moved without holding down the command key. I'm using PTLE 8.0.3 on a Mac Pro running 10.6.3. Any ideas why this functionality isn't working?
Old 07-02-2010, 03:32 PM
Default Re: fine adjustment of breakpoints not working
Never tried that. What works just fine for me is to zoom in, grab the breakpoint and move it(zooming in increases the resolution). Zooming in for horizontal adjustment, but increase the track height would help on vertical adjustments. On PC, the Ctrl key is the "fine" selector and, while it works fine for up/down adjustment, it has no effect for moving a breakpoint left or right.
Old 07-02-2010, 05:13 PM
It seems to allow me to freely move between grid lines in grid mode, but when adjusting audio volume breakpoints, it will not shift to fine adjust mode.
Old 07-02-2010, 09:00 PM
You can't do it in GRID mode.
Old 07-02-2010, 11:14 PM
ryanwilsonfive ryanwilsonfive is offline
I've posted about this in the Windows LE forum quite a while back, but didn't get much love on the topic. I have the same concern/problem. I swear in versions 7.0-7.4, I was able to make fine adjustments by holding Control(PC)/Command(Mac) while in Grid mode. A lot of my work is in Grid mode, so switching to Slip just to move by smaller increments kinda bites!
http://ryanwilsonfive.com
Old 07-03-2010, 06:42 AM
colinmansfield colinmansfield is offline
Oh good! I thought it was just me...
Colin Mansfield
Mac Pro, 2 x 2.4 GHz Quad-Core Intel Xeon, 32 GB RAM, OS X 10.8.5
PT 10.3.10, cheapo Behringer interface (because my Digi 002 Rack stopped working)
Bandcamp
Soundcloud
Fine Adjustment on AAX seems to be Broken? Neil Pickles AAX Plug-ins 4 06-07-2013 01:39 PM
Key command apple / not working to insert breakpoints. Randys@studiocity.com Pro Tools 9 0 09-28-2011 04:28 PM
pt8 was working fine.. then! shanemccarthy Pro Tools M-Powered (Win) 3 11-24-2009 05:36 AM
Fine volume adjustment gbours Pro Tools TDM Systems (Mac) 3 05-02-2006 07:23 PM
Strip Silence and Fine Adjustment... Still a bug? SimpleNatureSpirit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2004 11:22 PM
