Old 02-08-2017, 06:06 PM
Taffypro Taffypro is offline
Default Turning off the delay in a bounce
I've recently upgraded to PT12 and am confused by a slight delay I get when I bounce audio. In older versions (if I remember correctly) you could select a precise bit of audio and bounce it (with no plug ins) and it would align exactly to the original audio when you imported it. Now when I do a bounce there is a slight delay. When I look at the audio waveforms I can see that they are slightly off, and of course I hear it.
Is there a setting I'm missing (so that bounced audio it will line up exactly as the original)?
Thanks,
Gary
Old 02-08-2017, 06:17 PM
johnnymacvkguitar johnnymacvkguitar is offline
Default Re: Turning off the delay in a bounce
I am using 12.7 and just noticed the same thing...Delay using "commit up to this insert" with Steven Slates Trigger..
Ouch this is going to become a problem. Now I have to go back and look at all the files I have bounced...:-(
Old 02-09-2017, 07:54 AM
ShortWarning ShortWarning is offline
I also had this with trigger. I thought it was down to the sample I was using but maybe not. I had to drag it back inline.
Old 02-09-2017, 08:11 AM
Gary - Is this with a specific plug, or any plug? I use commit to insert on a daily basis with Melodyne and haven't seen a problem. I also bounce mixes/stems fairly regularly and have no timing issues - how much of a timing issue are you seeing?
I've had issues with incorrect latency reporting from Slate plugins in the past.
PT12 HDX
Mac OS 10.10.5
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-09-2017, 11:03 AM
TOM@METRO's Avatar
You must check every bounced or committed VI track for delay. That's just the way it is for now.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-09-2017, 11:07 AM
wwittman wwittman is offline
Only VIs?
Bounce to disc delay Weg Pro Tools M-Powered (Mac) 3 12-07-2012 04:57 AM
PT HD 9.0.5 Lion Bounce delay BobStrenger macOS 1 11-30-2011 11:43 AM
Delay's Not Following When I Bounce 2 Disk??? M2E Pro Tools TDM Systems (Mac) 10 08-23-2007 10:28 AM
Cancel Bounce Delay CraigLearmont Pro Tools TDM Systems (Mac) 0 02-04-2004 10:46 PM
how can i compensate delay when bus bounce .help please Esquivelzeta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-22-2001 07:53 PM
