Re: Have PT 11, how to install PT 10?
I can only recommend my interface (in signature). Look at other signatures.
Totally depends on your budget : http://www.sweetwater.com/feature/pr...interfaces.php .
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Creative SoundBlaster is nothing more than a gamer soundcard. Not recommended for real audio work. Ditto for the onboard Realtek. As to what's good that depends on your budget. MOTU makes some good stuff that won't break the bank. Recommendations are also hard to make not knowing what I/O ports you have on your computer (USB, Firewire, etc.) as not every interface has every connection port. Not too many people make good internal soundcards anymore, especially if you're looking at budget solutions. |
I should have talked to you BEFORE we fell for the PT hype.
Time for Plan B . . . Thanks. |
Found someone at Sweetwater who recognized the problem. It may be that installing 10 after 11 caused a critical file to be stepped on. Solution is to install 10 first, then 11. We're getting a USB box for output; this may cure the silent PT 10 problem.
Thanks for the help. |
Weird that the install of PT10 after 11 would cause a problem. What USB interface are you getting? |
#16
The way the sales engineer explained it, a particular file gets trashed if 10 is installed after 11. After removing 11 and fiddling with some settings, I got 10 to make real sounds. Even so, we're not going to rely on the computer's built-in audio hardware.
We may put 11 back on this computer . . . and we may not, at least, not right away. The USB I/O is a Focusrite Scarlett 2i2. |
#17
I think I understand now about the install sequence. PT10 and 11 share some of the same folders, at least on a Mac. The aax plugins folder for one and I think there are others shared as well. |
Mountain Lion/PT Install/Ilok install problems | alex obradovic | macOS | 7 | 07-14-2013 06:19 PM |
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! | shamanrock | Windows | 13 | 12-27-2012 04:39 PM |
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions | b-pole | macOS | 2 | 08-31-2011 07:23 AM |
Can't install Pro Tools 8! Clean install, new system, Vista! | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 01-09-2011 11:16 AM |
Can't install Pro Tools LE - Insert disc but no option to install | Paul McConnell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-22-2010 08:13 AM |
