Old 12-14-2009, 10:23 AM
GrantFM GrantFM is offline
Default Best Video File Format for PT
Hello, I was wondering if anyone could give me any pointers of what the best (i.e. highest quality/ resolution) video file format and resolution for movie files to be imported into Pro Tools. In my experience, files (.mov, .mpeg, etc..) are being used more and more for "mix to pic" in advertising post, though a lot of the files I get are of a crappy quality and pixelate a ton. I would just like to be able to recommend a quality file format to the film editors to export so that when I have clients in the room, it looks professional.
Any advice ?
Thanks in advance !
Old 12-14-2009, 10:28 AM
Craig F Craig F is offline
Default Re: Best Video File Format for PT
.mov is not a format, it is a generic extension that means movie file
inter-frame codecs (dv, photo-jpeg)work better that intra-frame codecs (h264, mp4)
quality has a relationship to how much processing power you can take from Pro Tools and give to image rendering
Thank you,
Craig
Old 12-14-2009, 01:28 PM
Craig, thanks for your reply, but actually .mov is a file format (Quicktime). Mpeg is more of a generic term, IIRC. Also, DV also is an intraframe codec, I believe.
Lastly, if quality of the picture in PT has a direct relationship to processing power allocated to image rendering, where do you adjust this ?
Old 12-14-2009, 01:34 PM
infiniteloop infiniteloop is offline
.mov is a not a file format, it's a container. The file within can be one of many, many codecs within the .mov container. There are an awful lot of threads in this forum about what works best - have a search.
Old 12-14-2009, 01:38 PM
Dallas Taylor Dallas Taylor is offline
I use DV. Looks great & plays well with Pro Tools. con: It's huge.
If you're Editor is local, it shouldn't be a problem.
However, if you're working over FTP, DV will be way too big.
Even if I receive an H.264 via FTP, I export it to DV before importing it into the session.
DALLAS TAYLOR CAS/MPSE
/// Sound Designer/Mixer @ Defacto \\\ Twitter Facebook
Old 12-14-2009, 02:12 PM
danijel danijel is offline
Gentleman, I am impressed by the amount of correct information used in this discussion:
YES - ".mov" IS a file, a format, a generic extension, a container, it means "a movie file".
We should write Webster to include these fine definitions in its thesaurus!
Danijel Milosevic
Old 12-14-2009, 02:26 PM
slipdiskdave slipdiskdave is offline
I actually find MP4 and h.264 to be the best formats. I agree with Dallas that DV is awesome, but is often too big for the remote stuff we work on. The thing to remember, is that Data Rate plays a larger part in how sluggish PT will react to the MOV, more so than actual resolution size. For example, an MP4 at 1920x1080 with a fixed data rate of 1000 will play much faster than an MP4 at 640x360 with a fixed data rate of 5000. When encoding an h.264, the default setting for data rate is usually "Automatic" which uses the highest manageable data rate at given point. Great for the video; bad for PT.
Whenever I get a squirrelly QT, I usually convert it in QT Pro to a 640x360 (640x480 for SD) MP4, with a data rate of about 1000, and a quality of High. Gives me enough resolution to see what's going on, but small enough for PT not to freak out. Your playback will also vary depending on your computer.
Best of Luck!
Old 12-14-2009, 02:49 PM
koo_koo_bonkers koo_koo_bonkers is offline
Great tip.. When transcoding from AVI/Fraps codec to .mov DV I'm wondering if its possible to make DV "look better", even better than using the "High Quality" button in QT. Can I set the quality to high or the date rate higher too ? I use Quicktime 7 and / or Mpeg streamclip to encode video.
thanks
MacPro 5,1 - 2 x 2.66 6 core - 32G Ram - SSD's - Mac OSX 10.12.6 - HD Native Card - Omni - Focusrite RedNet 5 - Avid Dock - iPad2
Old 12-14-2009, 03:25 PM
I must disagree. Try scrubbing backwards with one of these and watch the jerk and shake.
Thank you,
Craig
Old 12-14-2009, 07:25 PM
I totally agree, Craig. They are definitely not the best looking codecs. Let me qualify my previous statement: they are the best codecs for ME and the way I work, due to their usable, if not perfect visuals, and most importantly, small size, since in my line of work, that MOV is going to be FTP'd or e-mailed back and forth at least 6-8 times a day during the approval process. Thanks for letting me clarify!
HTML code is On
Which video file format to use? finalmixaudio Post - Surround - Video 6 02-19-2014 10:04 AM
What is the TFX File Format? fly_with_v Eleven Rack 10 04-15-2013 09:17 PM
Wave Format Extensible file format? Joe Mendelson Post - Surround - Video 8 01-07-2008 05:18 PM
*.tfx file format??? Jody Stevens Virtual Instruments 3 10-09-2007 09:36 AM
.wav file convert to .mid file format Eddie YP Pro Tools TDM Systems (Mac) 1 03-17-2000 12:33 AM
