#21
Re: FCP \"bug\" to watch out for...
Potential fix other than you suggested: The final cut editor can import audio files two different ways:. 1) using import from the menu or 2) dragging the file into their FCP session. Tell the editor if he's having problems to try to use File -> IMPORT audio vs. "dragging from a browser window." I've seen this work once before troubleshooting with an editor with PAL or HD audio issues.
#22
Re: FCP "bug" to watch out for...
"Ya canna change the laws of physics..." -Montgomery Scott Howard Sonnenburg Atomic Audio Ottawa, ON Canada |
#23
What OMF 24/23.98 bug are you referring to?
#24
The fact then when you export and OMF at 23.98 from FCP, it wrongly is read as a 24fps OMF, even though it's NOT... Simply changing the framerate of the session corrects the problem, but it's still a PITA...
#25
Yo CJ...WD here. This is the bug I thought we discussed once at TDS where the FCP 23.976 OMF will report itself as 24 frames when you launch Digitranslator, even thought the pix dept is cutting and exporting in 23.976. My workaround is to make sure the pix eds start their OMF exactly as my session template...say 58:30 and give me a 2 pop and tail pop as a confirmation. Since adopting this workflow I have had no probs on our "Everybody Hates Chris" OMF's. Importing it into my 23.976 templates in this manner makes them dead sync. If the session starts are not the same as was the case for a season then the 2 pop saves the day. Just move everything to that 2 pop start point and voila, sync. I did discuss this at AES with Gordon L. and sent him a screen grab of DigiTrans reporting the 24 frames...haven't heard back. I also brought it to Apple's attention when they visited EHC post at Paramount, but I think Digi and Apple should be finding out a real solution to fix the false reporting.
#26
#27
WD see no acronyms! |
#28
Has anyone tried using Dumpster (second from the top) for this type of a situation? The program changes the way that quicktime looks at and plays plays a file. We have used it on a few occasions when we needed to deal with frame-rate issues. Anybody else tried this?
#29
Hi
i have discovered something while conforming a project by Titan (at least i thought i was on something) i had this 23.976 DVCPro HD project that was cut in FCP and then i received the EDLs. followed the usual worklflow with Titan. i realized the project Titan created was a true 24fps PT project eventhough 23.976fps is choosen in Titan. the red light on video track in PT was on after importing 23.976 video. session information confirmed that. apparently FCP stamps the 23.976fps projects as 24fps on EDL exports. just wanted to let you know u might know already |
#30
seen this same thing happen in non-24 frame rates ..
happens with 29.97 NDF and DF ... does not happen in FCP ver 5 .. only 6 so far ... cheers john
One to watch... | Carl Kolchak | Post - Surround - Video | 3 | 08-20-2012 07:24 AM |
PT 9 Bug to watch out for | bluesfrequency | Post - Surround - Video | 0 | 11-25-2010 12:27 PM |
Does anyone here watch TV | bigbadhenchman | Post - Surround - Video | 32 | 01-18-2006 02:43 AM |
Un-Install 6.1.1 - What to watch out for... | Blind Dog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-04-2004 02:41 PM |
Watch this!! FW 1884!!!!! | clusterer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-03-2003 09:44 AM |
