"DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or
"DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or a firewire drive could be having trouble due to extra firewire bandwith or CPU upload."
thats the error message i got before my mbox 2 pro gave out on me. i've re installed PT8 and tried all my firewire connections....do you think my mbox 2 pro is really dead? its not recognized in my device manager and theres no signs of life at all.... my build ASUS P5K Deluxe Intel Q6600 2.4 GHz 2 GB DDR2/800 MBox2 Pro PT8 help please! |
Re: "DAE can't get audio from drive fast enough. Drive may be too slow or fragmented,
i was getting these same DAE (9073 i think) with a stem mix i was using to test my PT 8 upgrade which had me stumped for a while
errors stopped when i edited the stems by removing all the silent bits on the stems and i managed to nearly get through the whole song then started getting hw buffer messages still, working my way through it and trawling through DUC for answers |
Have you tried the steps in the General Troubleshooting thread yet? If not - please start there...
The P5K series on-board firewire are definitely NOT compatible with Digidesign's firewire interfaces. We've been adding a dedicated card on the P5K-based system we use, and it solved this problem. Make sure this isn't the cause first.
Also, what type of drive are you recording to? The system drive? firewire? USB? second internal? and what speed is it?
~Matt Hollingsworth Lead PC Repair/Install Tech Sweetwater Service Department |
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I started having the same issue on playback. The same error message -9073. I was playing back from the computer hard drive (not recommended) or from a portable firewire. I went to the general trouble shooting page
http://duc.digidesign.com/showthread.php?t=54888 and performed the following: delete Pro Tools preferences, repair permissions, delete databases and volumes. I lost some data from sessions saved on my hard drive but I had copies on my firewire. I copied these back to the computer hard drive (not recommended) and it plays now without error. However, when I try to play from my firewire I still get the error message. Ben MacBook Pro OSX 10.4.11 2.2 GHz 2GB Pro Tools LE 7.4 MBox 2 Mini Iomega LPHD160-C firewire |
Not attempting to record to your system drive are you? That's a BIG problem.
Did you format the Iomega drive using the OS X Disk Utility?
I can't find specific info using the model number you gave me - is there any other model info? How are you connecting the drive to the computer - which port and what type of cable? Are there any other peripherals attached? |
http://tinyurl.com/d6dt7g Also connected is the MBox 2 Mini which is connected via USB outlet on the same side as the power cord. The Iomega has the capacity for external power but I've not tried that yet. Ben Ellis |
DAE drive too slow or fragmented. Stop playback | fab leseure | Pro Tools TDM Systems (Mac) | 21 | 11-15-2011 03:30 AM |
Drive too slow or fragmented messages... | andrewd | Pro Tools TDM Systems (Mac) | 5 | 10-30-2010 12:26 PM |
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there | huncke | Pro Tools TDM Systems (Win) | 6 | 02-23-2010 02:06 PM |
"DRIVE TO SLOW OR FRAGMENTED" | RoyaltyOnline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-12-2006 09:50 PM |
Drive is too fragmented or too slow? | scenaria | Pro Tools TDM Systems (Mac) | 2 | 05-26-2001 05:30 PM |
