Help Setting up Artist Mix with a Router
Hi guys
need some help.. despite being a computer user for 15 years i still feel like a noob everytime it comes to network stuff I need help configuring my artist mix so that it actually works everytime I go through phases of it working for months, then as soon as something changes in my network setup it sits unused as i just cant get the device and mac to work Im using mac high sieera 10.13.6 MAcbook Pro 2017 Touchbar. it was working until i added a network PC slave for Vienna Ensemble Pro 6 - i have since left that PC slave switched off I am using a basic TPLINK router with my artist mix plugged in, my PC slave and my WIFI LTE Router plugged in for internet. this then goes to my Gizoo USB-C hub with a ethernet port. I have tried using an old trusty apple USB-ethernet converter as well. the connection in network prefs always shows Green... happy and active I have my Artist Mix configured to static address. dhcp: set to No IP address: 010.000.000.020 Subnet: 255.255.255.0 on my mac my settings are. USB ethernet controller (from my Gizoo Usb C hub with ethernet port) [I]Configure IP4: Manually IP address: 10.0.0.2 Subnet: 255.255.255.0 Router 10.0.0.254 DNS server: 10.0.0.254[I] Eucontrol v18.3 nothing but the good old AVID sign on the Artist Mix Why? |
Re: Help Setting up Artist Mix with a Router
Well it’s a little hard to determine with the info you provided but I’ll take stab at it.
Based on this info... I have my Artist Mix configured to static address. dhcp: set to No IP address: 010.000.000.020 Subnet: 255.255.255.0 on my mac my settings are. USB ethernet controller (from my Gizoo Usb C hub with ethernet port) [I]Configure IP4: Manually IP address: 10.0.0.2 Subnet: 255.255.255.0 Router 10.0.0.254 DNS server: 10.0.0.254[I] It looks like your Mac and your artist mix are assigned the same IP address, thus conflicting. You’ll need to assign them different static IP’s if that’s the route you want to take. Make sure those IP addresses are within range of your routers settings. It would be helpful to post a screen shot of your Eucontrol setup window to see if Eucon is seeing the Artist Mix. |
Use DHCP and not static on your Artist Mix.
It's a safer bet in your circumstances. (I'd also ask why your router/DNS server is set to 254? traditionally it is 1 for networks. So it should be set to 10.0.0.1. In addition, if your router is passing DNS, it is better to not assign a DNS server so that your WAN can pass the actual DNS servers to your local LAN devices.) To its2loud, he has his mac set to 2 and his Mix set to 20. No conflict. However, this is a case of clearly not being comfortable with networking so it's best to let DHCP do what it does best. It'll save a lot more frustration in the long run. Unless the OP has a lot of network devices which it appears he doesn't.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 01-31-2019 at 09:27 AM. Reason: grammar fix for readability |
hey guys!
thanks for your responses What i did was plug the Artist out of the Router and straight into an apple USB ethernet converter. I then changed the subnet mask on the artist mix to 255.255.0.0 and the same on theethernet usb setting on the mac and it works fine. I was weary about changing netwrok settings on the other connection as I only just got Vienna Ensemble Pro to be working with static IPs and didnt want to compromise this Why would changing the subnet mask help? |
Also - Is 010.000.000.020 not the same as 10.0.0.2? just losing the first decimal place? |
You don't need the preceding 0's - 10.0.0.20
Unclear of what you've done. Sounds like you unplugged the Artist Mix from the router/switch and plugged it directly to the computer now? That would be the major fix. Also unclear of how many network interfaces on your laptop are hooked to the same network. For instance if you have your wireless on the laptop hooked to the same network as your wired USB where they are both using 10.0.0.xxx ip addresses, you can have problems.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
True...but most routers require you to reserve these static addresses otherwise you might get 2 the same.
I will try setting the dchp to non static on the artist mix and see if that works |
As Eddie pointed out, using a mixed DHCP and static IP network, you may need to reserve the IP addresses used for your static devices. If you don't know how to do that on your router, there are some easy workarounds:
1) If the static IP device is never shut off, the router won't allocate that IP accidentally to a DHCP device. So if you never turn off your Vienna Ensemble Pro, it will hold that 10.0.0.20 number you have given it so that the router/DHCP won't hand that out to some other device via DHCP. 2) If you start allocating IP addresses with high numbers to static IP addresses, the chances of your DHCP given number getting into that range will be highly unlikely unless you have a lot of devices. For instance, if you give your Vienna Ensemble Pro computer the IP address of 10.0.0.250, you would have to have 249 devices attached to the network before the DHCP server (router) would get to hand out 10.0.0.250. And most consumers don't have that many devices on their network. This is the safer workaround if you don't know how to do an address reservation on your network. From what you describe, the easiest solution for you is: On your laptop, turn off your wireless! Connect your laptop to your router/switch via the USB ethernet cable. If you want to set this to a static IP, set it to 10.0.0.250 Connect your Artist Mix to your router/switch via an ethernet cable. Set this to DHCP. Connect your Vienna Ensemble Pro computer to your router/switch via an ethernet cable. If you want to set this to a static IP, set it to 10.0.0.251 Do not turn on your wireless while working. If you do, you've created two paths to the network and that will screw things up because your computer will not know how to send data/communicate (over wireless or via the ethernet cable.) There's more to it than this but this is the simple explanation.
Router RV325 setting | shauli | System 5 | 0 | 04-05-2018 08:08 AM |
Artist Mix's Ethernet connects to a Router? | Rockman413 | Artist Series | 1 | 08-28-2016 11:45 AM |
Best switch/router for Artist series? | ThosSounds | Artist Series | 2 | 12-21-2014 04:16 PM |
Artist Mix Setting this up is killing me!!! | syMPh | Artist Series | 12 | 06-25-2014 04:01 AM |
Finally, switch or router for multiples artist units ? (and which one to get ?) | Loudyman | Artist Series | 4 | 03-25-2014 05:22 PM |
