Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 09-05-2015, 05:54 AM
clausiii's Avatar
clausiii clausiii is offline
Default First does quit on launch when plugins scanning
As the title says, it suddenly quits during startup when plugins were scanned.
When i remove the plugins from the plugin folder, everything is fine...
Din't know which plugin is the cause, i have many...
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 09-08-2015, 03:40 PM
DigiTechSupt's Avatar
Default Re: First does quit on launch when plugins scanning
Hi clausiii,
are the plugins you're using, downloaded from the MarketPlace in Pro Tools First? only plugins from ProToolsFirst's Marketplace are the ones that will only work on PTF.
Best regards,
Tope
Avid Audio Tech Support
Support FAQ
Old 09-13-2015, 10:52 AM
zoff zoff is offline
Originally Posted by DigiTechSupt View Post
Hi clausiii,
Best regards,
Tope
I also have Pro Tools 11.3.1 installed. I would like to use Pro Tools First in cases when I don't have my iLok with me.
I'm having the same problem as the OP, even if I move my Plug-ins (used with PT 11) to a different location temporarily.
macOS High Mojave 10.14.2
2.8 GHz Intel Core i7 MacBook Pro Retina, 16 GB RAM
Pro Tools 2018.12
Apogee Duet (Firewire)
Old 09-14-2015, 07:28 AM
Hi zoff,
Mac OS X 10.10.5 is not yet supported in Pro Tools First. Here's the KB FAQ. I suggest you subscribe to this FAQ for updates.
Regards,
RC
Support FAQ
Old 09-14-2015, 05:35 PM
Hi zoff,
Regards,
RC
BTW it worked fine from a 10.11 beta on a clean partition. I didn't test it extensively, but I got further than on 10.10.5. I've now updated to 10.11GM from the previous 10.10.5 system and I don't get the "Shoe tool..." error, but it crashes on startup.
I realize these OSs are unsupported, this is just a FYI.
Pro Tools 2018.12
Old 09-18-2015, 10:33 AM
clausiii's Avatar
Yes but it doesn't crash when no plugins are in the plugin folder.
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 09-18-2015, 10:52 AM
I removed the plug-ins out of the folder and still crashes.
Which OS are you using?
Pro Tools 2018.12
Old 09-18-2015, 10:53 AM
clausiii's Avatar
I tried it with both, Yosemite and El Capitan.
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 09-18-2015, 11:08 AM
Just to be sure, are you using El Capitan Golden Master?
PT Free worked on my system with the previous beta version of El Cap.
Pro Tools 2018.12
Old 09-19-2015, 02:48 AM
clausiii's Avatar
Yes, GM of El Capitan!
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Pro Tools 10 HD runs out of memory when scanning plugins dj_grimmace Pro Tools HDX & HD Native Systems (Mac) 10 09-16-2015 06:11 AM
10.3.10 ran out of memory scanning plugins crizdee Pro Tools 10 29 02-08-2015 12:24 PM
PT 10 plugin scanning error on launch benbass1991 Pro Tools 10 2 01-14-2014 09:16 AM
Live Lite 7 for Digi not re-scanning plugins Gothboy Virtual Instruments 0 09-21-2009 10:10 AM
quit and re-launch PT .. ? Uelogy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-10-2006 05:39 AM
