Old 05-20-2019, 01:53 PM
digifactory digifactory is offline
Default Recreation of the Pro Tools Experts Benchmark Test (iMac Pro)
I am a bit bored atm and trying to recreate the benchmark test according to this setup:
https://www.pro-tools-expert.com/hom...r-test-session
Mr. Ivey started 256 instances of Boom with one single click (https://youtu.be/PYHMinrhh3o?t=159). How can I manage a simultaneously start of all those plugins. I have to do this with every single instance manually (push the green play button within the plugin) to get any sound out of it.
Regards
Composer/Keyboarder
iMac Pro 10 Core 64 GB RAM Vega 64
Pro Tools 2023.12/Ventura 13.6.1
Beyerdynamic DT 770 Pro
______________________________
Old 05-20-2019, 08:52 PM
685 685 is offline
Default Re: Recreation of the Pro Tools Experts Benchmark Test (iMac Pro)
https://app.box.com/v/PTE-Mac-Power-Test
http://www.pro-tools-expert.com/prod...or-your-studio
Old 05-21-2019, 04:47 AM
@685:
thank you for the helpful link.
Composer/Keyboarder
Old 05-21-2019, 04:56 AM
I was able to extend the test session with my 10-core iMP, running PT 2019.5, Mojave 10.14.5 without any errors as follows:
o 128 audio tracks with channelstrip and d-verb enabled.
o 39 (instead of 7) of these channels with avid eleven running.
o 256 instrument tracks with boom enabled
Although, i was not screen recording at the same time a 10-core makes sense if it comes to heavy plugin load. More cores, more "worksharing". Weeks ago I was told by someone, that "more cores do not have any big effect because they are mostly sitting on the couch". Disagree.
PS: Maybe PT 2019.5 is now more efficient with respect to higher core count as well.
If someone is considering buying an iMac Pro, go for the 10-core instead of 8-core or higher.
Composer/Keyboarder
Old 05-21-2019, 05:08 AM
Meads Meads is offline
I think who you are referring to is me, and you can disagree all you want, you obviously didn't understand what I was saying.
I said it depends entirely on your session. If you have many tracks loaded with plugins, that are not reliant on or connected to each other, then that load can be spread across several cores, the more the better. If however you have many tracks bussed together and the respective Aux-tracks are doing a lot of the work, then a higher clock count is more beneficial than a higher core count.
In my mixes (post, mind you) I use pretty long bus chains. And therefor my 6 core Hackintosh that runs at 5GHz is able to do an offline bounce in almost half the time my 8 core iMac Pro does for certain sessions.
So, yes, in your "benchmark test" that - at least for me - has no real ties to any real world scenario, the 10 core does a better job. And I'm pretty sure the 18 core would do an even better job.
This is unreflected nonsense and not sound advice.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 05-21-2019, 06:17 AM
I still highly recommend going for the 10-core. If you are willing to spend this money into a mac, throw a little in the bargain and go for 10-core instead of 8-core. the overall benefit is worth it.
Composer/Keyboarder
DVerd's test on iMac 20' 2,40 4Go MatthieuH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-22-2008 03:48 PM
Fascinating Benchmark for new iMac Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-30-2007 11:50 PM
Amy Winehouse/Mark Ronson recreation? KaProducer General Discussion 1 06-04-2007 01:36 AM
New CPU benchmark test rpowell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 32 03-22-2004 06:32 AM
new improved way better benchmark test for Macs Freeheel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 120 05-17-2003 05:12 PM
