Avid Scorch (iOS) ForumScorch for iPad Support FAQ |
System Configuration for Pro Tools 10.3 update
Hi I've just installed Pro Tools 10 on my new machine, after finally getting that stupid iLock think go work - OMG what a nightmare!
Anyway, I was also advised to install 10.3 update. I'm not entirely sure why, because it seems to work anyway, but I thought I'd install it anyway and see. Does anyone know why? I'm running mountain lion. So my main question is, I'm installing the Pro Tools 10.3 update and it's asking about my system configuration and I have to choose one, and I don't know which one to choose: it says: "Please select what PRo Tools hardware system you are installing software for, as different hardware will require different components to be installed:" and the options are: "Avid HDX, HD Native, or any non-HD hardware" or "HD TDM (HD Core, HD Accel, HD Process)" I have no idea what either of these mean, does anyone know what I should choose? My specs are: iMac 21.5 inch 2.8 Ghz Intel Core i7 16 GB 1333 Mhz DDR3 RAM OS X 10.8.2 Thanks, I hope you can help. |
Re: System Configuration for Pro Tools 10.3 update
I have the same question. I was trying to install PT 10.3.1 but I was not sure what to choose when I got to this step. Did you figure it out in the end?
specs: iMac 21.5" 2.5 Ghz 8 GB 1333 Mhz DDR3 OS X 10.7.5 |
Choose the top one. The lower is for the 'old' pcie hd systems. (with 'dsp farms') you both have iMacs so I am sure you don't have that system....
Pro-Tools Set-Up & System Configuration | MEWCO | Getting Started | 61 | 11-01-2014 07:07 PM |
can anyone help me re: system configuration | Deni | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-30-2009 02:59 PM |
Digi 003 Rack+ and Avid Mojo SDI - Pro Tools LE system configuration help | DLoop | Post - Surround - Video | 13 | 01-16-2009 09:45 AM |
New System Configuration | rokkit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-14-2008 12:32 PM |
Mix system, best configuration? | stargazer | Pro Tools TDM Systems (Mac) | 4 | 05-13-2003 10:28 PM |
