Outboard reverb connecting to 003
I am trying to get my Yamaha SPX-90 hooked up to my 003. I have the #8 output connected to it and i am getting a feed to it (shows input signal level on SPX-90) but i can't seem to get it back into a session. The 003 manual says to use analog inputs (such as 7&8). I have connected the SPX-90's L/R outputs to analog inputs 7&8 and when i add an Aux in to my session it won't see the input signal from the SPX. I put the SPX outputs into the Aux in on the 003 and i hear the reverb, but i want to have this be part of the session so that when i bounce to disc the reverb is there. I want to use this instead of a plug in reverb. I have tried using an instrument input channel as well as an AUX channel but i am having no luck. I have tried assigning this as an interface as well as a bus on the input of these channels with no luck. I hope someone can help me. The manual is a bit vague on this.
Re: Outboard reverb connecting to 003
In Pro Tools go to setup>I/O>Input Tab>Click Default. Then click default in Output & Bus Tabs then>OK
Keep the L/R from SPX-90 to 003 channels 7&8 and on a Stereo Aux channel select inputs 7&8.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
You might also use a stereo AUDIO track and record the reverb into the session(so its permanent). Handy if at some later date, you want to use the SPX again for another effect in the same session. Personally, I would just get a better reverb plugin and skip all the hassle. Breverb, IK Classik reverbs and the Lexicon LXP bundles are excellent on a budget(as is Redline from 112db). I have(in the past) used a hardware verb for effects on vocal during tracking, by splitting the output of an external preamp so it feeds both Pro Tools, and the reverb input
connecting outboard to mbox??? | Bob333 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 01-12-2006 04:30 AM |
Outboard gear and connecting to 002 | Doug May | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-06-2006 05:59 AM |
Connecting outboard digitally | BradG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-24-2003 07:33 AM |
connecting 192 interface to 96k outboard fx? | fourthtunz | Tips & Tricks | 4 | 10-02-2002 04:56 AM |
connecting an outboard compressor | jinglemaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-17-2002 02:10 AM |
