Old 10-14-2008, 03:47 PM
Jeff ONeil Jeff ONeil is offline
Default no horizontal scrolling in LE
Need some help folks.
I have a Macally dot mouse that worked perfectly when scrolling horizontally in the edit window when used with the shift key. Now it won't.
I did, for whatever dumb reason, download the input manager for the dot mouse. Thats when the troubles began. I've deleted the "input manager" from Macally, and still no luck.
I have LE version 4.2 running on Leopard 10.5.
Do I have to re-install Leopard, or re-install PT LE? Or, hopefully there is a process running that I can't find thats creating the problem.
Would really appreciate the assistance.
Regards,
Jeff
Old 10-14-2008, 04:06 PM
Phil Ogden Phil Ogden is offline
Default Re: no horizontal scrolling in LE
Might be a Preferences that remains from the input manager install. Have a trawl through and see if you can find and delete the offending article.
http://www.myspace.com/philogg
Old 10-14-2008, 05:06 PM
I fixed the problem. The Macally dot mouse had somehow corrupted the Apple mouse driver in the process. Did a re-install of Leopard and then PT LE and it works fine now.
Thanks for the idea phil, it may have worked as well.
Jeff
Horizontal Scrolling on Windows 7 (PT9) Rom37 Windows 10 07-29-2014 07:23 AM
Horizontal Scrolling artsads 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-15-2009 07:08 PM
Horizontal scrolling none in 8???? stixstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-13-2009 05:53 PM
PT 8 horizontal scrolling too slow?? Shan Pro Tools M-Powered (Win) 0 12-26-2008 10:23 AM
Horizontal Scrolling.... TOO MUCH TO ASK FOR!? s0nguy Pro Tools TDM Systems (Win) 5 11-26-2005 01:21 PM
