Old 09-17-2023, 10:47 PM
Ulf Manú Ulf Manú is offline
Default aligning the grid to a free tempo piece
I have a piece with quite a lot of tempo changes. I did import the midi tracks from Logic to get the tempo information into PT, then imported the audio files from Logic, including a click track I prepared in Logic. The click track form Logic works fine with the imported audio, but the grid in PT does not line up with the transients of the click. I tried Beat Detective and Beat Markers, but it does not show the desired results. How can I get a handle on this?
Thanks for any kind of help!!!
Old 09-20-2023, 12:24 PM
Default Re: aligning the grid to a free tempo piece
Not sure if this helps, but if you search youtube for "create a tempo map in Pro Tools"(without the quotes), you will see how to handle it in Pro Tools(lots of work, but it does work).
Grid lines not aligning with tempo map KimWexler Pro Tools 2 04-16-2022 03:16 PM
Having trouble aligning downbeats with tempo pianosdr MIDI 2 04-29-2018 03:20 PM
Aligning Midi to Tempo Map with Beat Detective-Can't move analysis markers. Dizzi45Z Tips & Tricks 7 08-25-2015 02:35 PM
Not aligning to the grid when duplicating loops / regions. Off by small smaples. xstortionist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 03-11-2011 06:47 AM
Aligning imported Drum audio to grid ohansen_5150 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-18-2004 05:56 PM
