Old 04-17-2023, 02:51 AM
Analog_ Analog_ is offline
Default 192 full analog interface
I've read in the manual that the 8 analog inputs (slot 1), 8 analog outputs (slot 2) and the 8 digital I/O (slot 3) are hardwired on the 192 interface whereas only the 4th slot is available for the optional cards (analog A/D or D/A or digital I/O).
I was wondering whether it's possible to take the digital I/O (slot 3) card out and install an optional analog A/D and an analog D/A on slot 4?
Old 04-17-2023, 07:40 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 192 full analog interface
No.
The digital card does not need to be installed, but then it is a standalone box. Only slot 4 can accept anything.
This was fixed with Avid HD interface boxes.
Janne
Old 04-17-2023, 07:50 AM
Thanks!
Old 05-14-2023, 01:40 PM
Sugarnutz Sugarnutz is offline
I got a great deal on a 192 Analog on eBay for like $75 because the cards were in the wrong slots and it wasn’t working properly. When I got it I rearranged the cards to the proper slots and all was right with the world.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Old 05-14-2023, 02:56 PM
JFreak's Avatar
Janne
Old 12-04-2023, 10:00 AM
aaquilato's Avatar
aaquilato aaquilato is offline
Originally Posted by JFreak View Post
No.
Hi JFreak. I'm having the same problem with an older 192 interface.
Is slot 3 the 2nd (right) top slot? And slot 4 below that?
I'm moving cards around now.
Thanks.
AQ.
Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6
Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9
Black Lion modified OMNI HD w/XB clock
Multiple Black Lion modified 192 FM/XB interfaces
Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native)
Old 12-04-2023, 10:08 AM
looking at rear
bay 1 bay 3
bay 2 bay 4
Old 12-04-2023, 10:14 AM
aaquilato's Avatar
Thank you!
And bay 3 can be empty?
Or do I need a digital card in that slot for the interface to work?
I'm confused by JFreak's comment about it becoming a standalone box.
AQ.
Old 12-04-2023, 10:19 AM
BScout BScout is offline
Originally Posted by aaquilato View Post
Thank you!
3 can be empty.
"Standalone" is used incorrectly here. You always need an HDX/TDM card in use and the chassis has digital connections too.
Old 12-04-2023, 10:23 AM
aaquilato's Avatar
Originally Posted by Darryl Ramm View Post
looking at rear
bay 1 bay 3
bay 2 bay 4
I have an interface set up like below and it works fine.
I know that there is a PSU limitation as JFreak mentioned.
Could it be that the ribbon cables were switched around on that side?
bay 1 = analog input bay 3 = analog input
bay 2 = analog output bay 4 = digital i/o
AQ.
Digi 192 Analog Interface finale Buy & Sell 0 06-28-2012 06:46 PM
Analog out card for a 192 Digital interface? studiomusic Pro Tools TDM Systems (Mac) 9 01-28-2011 08:06 PM
Analog interface??? williamlee Digidesign Hardware & Software 3 12-10-2002 03:13 PM
Okay we got the all digital interface - what about an all analog interface? uno1234 Pro Tools TDM Systems (Mac) 2 04-24-2002 12:50 AM
SDII/Digital Interface/Analog Interface Question Karmitz Digidesign Hardware & Software 1 07-15-2000 12:30 AM
