Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 08-17-2022, 12:08 AM
timsen timsen is offline
Default WINDOWS10 w/Carbon
Dear AVID Forum,
using PCs for professional tasks etc. -> Carbon is MAC only?
THX
Best regards
T
Old 08-17-2022, 12:29 AM
Default Re: WINDOWS10 w/Carbon
Stated and explained many times over that the limitation is AVB.
Now why Avid would lock this into AVB is another question, but equally fruitless asking. It is what it is.
Old 08-17-2022, 11:28 AM
K Roche's Avatar
K Roche K Roche is offline
As noted ----yes Mac only, because of the AVB ethernet connection.
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 08-17-2022, 12:57 PM
The odd thing is that S6L runs AVB protocol with Windows Embedded(if I correctly understand it) so it should be possible to come up with a Windows driver to make this work. Is there nobody tinkering with that?(I would guess not, but it sure would be nice.....)
Old 08-20-2022, 07:15 PM
LukeHoward LukeHoward is offline
The S6L uses RTX64, a real-time layer that sits alongside Windows. I imagine their AVB driver is running inside that rather than Windows itself. Supporting this on end-user systems would likely be expensive and complicated (as opposed to macOS where AVB is built-in).
https://lukehoward.com/
Old 08-21-2022, 06:43 AM
K Roche's Avatar
Given you are speaking "Professional Task" would seem to me
Solution #1 if you want the Carbon get a Mac and install Parallel Desktop for Mac
Solution #2 keep your PC and get a Mac for audio video work
bing bang bong. Done
System :
Enjoy the Journey
.... Kev...
Old 08-21-2022, 08:48 AM
Pass the bing bang BONG
Old 08-23-2022, 01:06 PM
tekn0 tekn0 is offline
I think windows 11 may have AVB support in the works. Presonus seems to have it working on ethernet, MOTU uses a USB connection for AVB windows. Not sure why Avid can't do it. I'm sure there is more to it though.
Old 08-24-2022, 04:22 AM
dominicperry dominicperry is offline
AVB is an Ethernet standard, so I'm not clear what it has to do with USB.
This is an OS issue, not an Avid issue, other than their choice to create a device (Carbon) which uses a protocol which is not available on one platform - i.e. Windows.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 08-24-2022, 04:33 AM
OK, here's a way to use your USB port to create an AVB Ethernet network connection. (RME Digiface AVB)
https://www.soundonsound.com/reviews...l-digiface-avb
I have no idea if this will work with Carbon and Windows, and it's very expensive, but RME are pretty good at making stuff work together. You could ask in their forums. https://forum.rme-audio.de/viewtopic.php?id=34949
Part of the problem is that AVB is not one standard but many, and it's not always clear which ones are needed or supported on any given OS, Ethernet port and device. Everything needs to line up for it to work properly.
Dominic
PT 2021.10 on windows10 21H2 FunkzzaJ Windows 10 01-11-2022 07:22 AM
Pro Tools auf Windows10 Fehlercode (-108) AlfredB.-Liedermacher Pro Tools 2 05-25-2021 01:14 PM
Protools 2021.3.1 not working with Windows10 v20H2 Pawan Pro Tools 6 04-25-2021 01:40 PM
Pro Control Windows10 nivam Pro Tools 10 5 06-12-2018 09:47 AM
