Old 09-26-2016, 09:12 AM
cheney5 cheney5 is offline
Default Loudness Correction Feature Films For TV
Hi All,
I am wondering how everyone corrects feature films to fit UK broadcast loudness specs?
I am getting feature films and I need to control the LRA value to 15 or lower to meet my broadcasters tech spec. The overall loudness is easier to fix.
Im currently using a couple of Pro Limiters to even the mix out. We dont have master stems or the time to remix. So the Stereo Mix is compressed with a low threshold/low ratio, then into a higher threshold with heavier ratio.
This is takes some gentle tweaking and come wet/dry adjustment but we are so far passing QC.
Does this sound about right? I am mimic the AC3 algorithm in dolby boxes.
Any advice would be greatly appreciated.
Cheers
Matt
Old 09-26-2016, 03:15 PM
Cheesehead Cheesehead is offline
Default Re: Loudness Correction Feature Films For TV
You're probably doing fine.
Just watch out for pumping and the dreaded sucking up the atmos between dialogue lines. Ugh.
The best way is with stems, but its basically raising the dialogue and then
limiting to spec.
I've found the Nugen LM Correct gives a good result with the right settings and their dyn-apt plugin.
Its quite expensive, but if you're doing a lot of that type of stuff it might be worth a look.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 09-27-2016, 03:22 AM
Thanks for getting back to me.
I have Nugen LM Correct, but that didn't give me the ability to control the LRA.
Is there a setting I'm missing?
Old 09-27-2016, 03:46 AM
Pete Gates Pete Gates is offline
LM Correct 2 - upgrade time!
Pete
Old 09-27-2016, 03:54 AM
I have LM correct2 installed. But it doesn't have the LRA boxes.
Old 09-27-2016, 03:59 AM
Ah, you need the dyn-apt extension, can't remember how much that costs!
Old 09-27-2016, 04:00 AM
Oh I see. Cool. Only £129 for upgrade!
Thanks
Old 09-27-2016, 04:47 AM
I'd credit cheesehead, I'm in the midst of upgrading various plugins (before the Autumn rush!) and only just found all this out myself.
Pete
Old 09-27-2016, 05:32 AM
Cheers guys.
Yes its the Dyn apt that lets you set LRA and short term if you wish.
The dynamics algorithm is very transparent to my ears, you can demo it if you want to check out first. It sometimes does the odd weird thing that you have to correct, but pretty good for a set and forget.
Good for creating online versions too.
It'd be interesting to know what others think of how it sounds.
HTML code is On
iZotope RX Loudness Control - Automatic Loudness Correction for Broadcast iZotopeInc AAX Plug-ins 0 05-21-2015 10:16 AM
S6 at Harbor Films NYC Tom Graham Avid S4/S6 7 02-21-2015 10:14 AM
Audio in films PAA Pro Tools 10 5 09-10-2012 08:35 AM
CALM Acts Audio Loudness, Average Loudness, Program Loudness levels... help needed qr2r Post - Surround - Video 12 11-10-2011 01:41 AM
How to see 5.1 films through 003?? ArmanC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-27-2011 06:13 PM
