Imported wav sounds poor
Hello,
I have a wav file, I open it in either audacity or just play it in MS media player and it sounds great, If I import it to Pro Tools 12 (same thing on previous versions) it looses a lot of it's quality and volume at 0, I am not using any plugins, If I then bounce to disk it sounds just as poor as when it's in Pro Tools. I'm and running at 44.1khz Any suggestions or is that just how it is? Thanks Jim |
Re: Imported wav sounds poor
Way more information is needed here. System specs? Bit depth? etc...How are you importing into protools?
Please only post in one spot, not that I haven't done it, but it usually garners a better result; or gets moved by the mods
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
System
windows 8 (does Pro Tools work well in windows 10?, I'll do the upgrade) Pro Tool 12.2.1 i7 4.Ghz 16 Gb of memory SSD for the OS and pro tools App SSD for Pro Tools recoding files Bit depth 24 I do file>import>audio It's a 38k .wav file |
I recommend upgrading to 12.3.1, not 12.4 What soundcard? |
38k is the file size
I am using USB to the Behringer x32 |
have you tried recording audio and seeing if you get the same result? Have you tried importing a different file? As far as I know, W10 is NOT qualified for protools. And from what I've seen, most are having better success with W7. I'm not a windows guy for audio anymore, so not much help there.
I tried it again today, I think what i was doing wrong had to do with a stereo file vs a mono file.
So playing it through audacity, media player or Pro tools it all sounds the same. Thanks for getting me in the right direction by trying different files, ETC. Jim |
Imported Audio sounds quiet | Rigoberto26 | General Discussion | 1 | 04-09-2015 11:21 PM |
Structure FREE Sounds 14 - 4 Cool Bass Sounds | RussUK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-18-2009 07:03 PM |
Structure FREE Sounds 14 - 4 Cool Bass Sounds | RussUK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-18-2009 06:50 PM |
Imported Stereo Audio sounds diffused | Jeremy Mix3000 | Pro Tools TDM Systems (Mac) | 6 | 04-08-2006 08:39 PM |
