Old 01-31-2016, 11:03 PM
Hatanin Hatanin is offline
Default Memory locations batch import & operations
Hello,
I'm about to edit a classical piece.
The ensemble wrote down the "editing score" and it looks like this:
Bar 1
00:34:29.500 - 00:34:33.400
Bar 2
00:35:47.000 - 00:35:49.000
Bae 3 - 7
00:37:39.500 - 00:37:58.000
Is there a way to Import the list as Memory location?
Is there a way to create an edit point (cut) on all markers after I have them all created?
Thanks,
Tomer
I'm running PT10.3.2 on a Mac OS10.8.5
Old 02-03-2016, 08:06 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Memory locations batch import & operations
Shalom, Aleichem
I don't know what your after....
Are you trying to line up the piece to the grid?
Are you trying to Sync the start?
B/C you can make markers relatively easy especially for 3 Bars.......
Daniel
Old 02-07-2016, 12:52 AM
Shalom,
I'll try to explain again:
I have a long session with multiple takes of a single piece.
The musicians made a list of segments that will form the final piece.
It is not grid based (there is no fixed beat) so i have to cut by absolute time.
My goal is to cut these segments and paste them together to create a final edited version of the piece.
first bar come from time:
Second bar:
etc...
I trying to find the quickest way to do this, for example:
1. Placing markers on each point -
marker 1 00:34:29.500
marker 2 00:34:33.400
marker 3 00:35:47:500
etc...
2. Group all track (edit group)
3. Copy regions between markers
4. Paste selection to end of time line
5. repeat until I have the edited version.
If I could somehow import that list (timecode entries) and automatically create markers, that would save me a lot of time punching in timecode for each marker.
Does this make more sense?
Old 02-07-2016, 07:29 AM
joachim's Avatar
joachim joachim is offline
You could copy from "00:34:29.500" in the text document the "34:29.500" part, highlight in PT the main counter (Min:secs) with the * on the numpad or clicking the minute number and hit paste and enter. Then double-enter on the numpad for creating a marker.
Problem : does not work with e.g. "01:10:00.000", since PT expects "70:00.000".
Or, if you do not mind not to differenciate between .500 seconds and 0.400 seconds in the end : you could use Word to search within those numbers for ".???" (meaning search for ".500" or ".400") and replace it with ":12" (12 frames). The search in Word must be set to "use placeholders" to accept "???" as 3 arbitrary characters ("500" or "400" or whatever).
Then use the copy paste method to copy "00:34:29:12" (the former "00:34:29.500") and paste it in the main counter set to Timecode.
The "...:12" represents roughly half a second (in a 25fps session).
Could be at least a little help.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Batch spot memory locations? AspenMx Post - Surround - Video 2 10-24-2012 04:00 PM
Import EDL as Markers/Memory Locations BigBangPost Post - Surround - Video 2 09-08-2010 09:33 AM
PT8 - Import memory locations - Tracks won't show Marc Hudson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-29-2009 07:05 PM
Memory locations - import/export ???? Jano Vesta Pro Tools TDM Systems (Mac) 2 09-03-2005 06:48 AM
Memory Locations ... Import/export? SPC General Discussion 0 11-12-2000 08:22 PM
