Old 01-20-2016, 09:16 AM
MarkH MarkH is offline
Default Dual Monitor setup
I hooked up a second 27" monitor so I can view the Edit and Mix screens simultaneously. Maybe my ergonomics are wrong, but I'm finding it hard to adjust to. Perhaps my monitors aren't angled correctly. Anyone feel like dual monitors can be little uncomfortable on the neck?
Old 01-20-2016, 09:30 AM
justus1900 justus1900 is offline
Default Re: Dual Monitor setup
I have found that to really use dual monitors the two monitors have to be the same size and type, I have identical Dell 24 inch monitors and it works out great, I have them both sitting right next to each other and the same angle and height, I'M about to buy identical Dell 27 inch monitors.
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 01-20-2016, 09:56 AM
I've got two Apple 27" LED monitors. I'm so used to looking straight ahead that now it's weird looking slightly left or right at all times.
Old 01-25-2016, 08:00 PM
zedhed's Avatar
zedhed zedhed is online now
Not surprising really, the larger the monitors the further away the viewer should be and 27" aren't exactly small.
Ideally it should only be your eyes that are moving not your neck, so it sounds like your monitors are too big for the distance you are from them.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 01-26-2016, 02:32 PM
Don't rule out going vertical
http://i182.photobucket.com/albums/x...psxmlogbix.jpg
Old 01-27-2016, 02:04 PM
GoGoJoe GoGoJoe is offline
I use 3 monitors. The resolution should be set to what your monitor is best recommended so there's no stretching. When you open pro tools don't maximize the screen and then you can stretch your pro tools main window across all 3 monitors then you can position your windows however you'd like
PC Dell XPS 8700, i7 CPU @ 3.40GHz, 4 Core(s), 8 Logical Processor(s). 32 GB RAM, Windows 8.1
Recording Pro-Tools 12.4. Mbox Pro 3 (Driver 1.1.10) FireWire CPU Interface w/ Presonus FADERPORT.
Dual monitor setup question Dave S. Pro Tools HDX & HD Native Systems (Mac) 22 07-21-2017 11:10 AM
Dual monitor vs single monitor setup Whasssaaahhh Pro Tools 9 23 03-17-2014 01:24 PM
Still on Dual monitor setup gerax Pro Tools TDM Systems (Win) 2 07-07-2006 12:51 PM
new to dual monitor setup... shynomi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-09-2005 10:16 PM
Dual monitor setup questions kjax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-17-2002 12:09 AM
