Crash at Bounce
I realize that the "Crash at Bounce" issue has been touched on in the DUC, but the problems I have seen appear to be similar but not identical. Using Pro Tools, 11.2.1, it has sporadic crashes when bounce is initiated. It doesn't seems to be specific about the format it is bouncing to- .wav and Mp3- and it is not predictable. Out of 10 projects the other day, it crashed on three. All projects are fairly small: no more than 12 tracks, 5 plugs-ins in use max, total run time not exceeding 4 minutes per piece, in offline-bounce mode, working with wav files samples at 192kHz, 24 bit resolution. System resources rarely exceed 32% used.The symptom: the screen goes blank, then acts as though power was shut off from the monitor. The computer won't even re-boot without unplugging. All in all, the system seems more stable than the errant recording halt in PT 11.1, even as infrequent as it was.
So, is this fixed in PT 11.2.2? In reading the notes for 11.2.2, it doesn't seem to be addressed. Is it? Machine ACPI 64x board AMD FX 4100 Quad Core processor 3.60 Ghz clock speed 12.00 GB installed memory 64 bit oper. Sys. Windows 7 Home Premium WDC WD500SABXX-01WERAI ATA drive ATAP Universal Audio Apollo Quad interface UAD 2 drivers Universal Audio Apollo playback engine 455 G. Disk drive; 372 available 1 TB disk drive Sonnet Technologies Allegro Last edited by mickeyrouse; 12-04-2014 at 02:10 PM. Reason: Add sandr report |
Re: Crash at Bounce
It's really a matter of trying different configurations to try to isolate the issue as it could be caused by any number of things.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Bounce to Mp3 crash | j.thomas | Pro Tools 10 | 1 | 11-14-2011 08:49 AM |
10.5.7 Crash On Bounce | andyj4308 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-28-2009 12:33 PM |
mp3 option bounce crash, HELP | pmueller | Pro Tools TDM Systems (Mac) | 2 | 12-17-2002 10:37 AM |
Bounce, crash, now PC won't start !?!?! | skymuse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-16-2001 06:17 AM |
Crash After Bounce | Bryan | Pro Tools TDM Systems (Mac) | 3 | 03-31-2001 07:45 PM |
