Old 11-29-2014, 11:34 AM
born26s born26s is offline
Default ASIO Sample Rate is not supported by one or more USB interfaces
I use PGMusic Band-in-a-Box, as well as Audacity and iTunes. However, if any of these are open when I open ProTools 10 or 11, I get an error that the "ASIO Sample Rate is not supported by one or more USB interfaces" and Pro Tools won't open. I then get a chance to send my error to support.
However, if I open ProTools first, I cannot play audio from Audacity, iTunes, YouTube, or my Windows Systems sounds.
It seems that there is an interference issue that I just can't figure out how to resolve.
I use an M_Audio Fastrack, Windows 8.1. I am at the latest revisions of PT 10 and 11, I also have recently re-downloaded installed the Fastrack driver.
Any ideas how I can make PT play friendly with the other audio tools I use.
Old 11-29-2014, 02:12 PM
ChuckS ChuckS is offline
Default Re: ASIO Sample Rate is not supported by one or more USB interfaces
I do not believe that ASIO is multi-client so the interface cannot be shared by multiple apps. PT is ASIO and the others are most likely using Windows Audio which can be shared between apps.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Avid HD ASIO Driver Locked Sample Rate Keith Moore Pro Tools HDX & HD Native Systems (Win) 10 11-16-2013 12:53 AM
ASIO one or more usb ports sample rate not supported trev27 Pro Tools SE and Essential (Win) 2 12-06-2012 03:50 PM
ASIO driver sample rate question smazur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-24-2008 11:20 PM
Which USB/FW interfaces supported? randomsample Digidesign Hardware & Software 1 09-14-2006 03:05 PM
Changing Interfaces Changes Sample Rate? Iain Graham Pro Tools TDM Systems (Mac) 4 06-07-2005 06:20 AM
