Old 07-07-2013, 10:17 AM
popajoe popajoe is offline
Default PT11 fix for can't find AUDIO device/ Controller/ personality/Mid.
Hi' this is my updates ;
For Ex Audio Interfaces on win/mac;OS's.
For timing error ; mid problems ; can't find interface or can't load setting of interface selected; ect's ; play back/ recording problems .
Its your OS : Try this go to your OS sound card an disable All your audio interface IOs there.
your sound card is in your control panel
disable each one: outputs an mic inputs that have your interface name on it.
Go to your OS sound card and disable all your audio interfaces ins/out; mic's. then reboot .
This also helps Vst's that use your interfaces IO's
I hope this helps ! it work for me.
Old 07-07-2013, 10:23 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: PT11 fix for can't find AUDIO device/ Controller/ personality/Mid.
Hi, Thanks for posting. What interface are you working with?
Chris
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-09-2013, 06:13 AM
Hi' (2) Mbox3gen (1) m-audio 610 (1) m-audio projectmix.
This fix ; bpm off ; can't fin interface; can't set sample rate ; pops/crack sound; also some vst's had problems that used the interfaces I/Os have occurred here !
My finding is the OS's are not releasing the interface to PT ect's an my i say it's not just Protools this is happening to. but this works
Old 07-22-2013, 01:16 PM
i used
Mbox pro 3gen 8x8 some of our customer used it here
so i have to look at every thing before posting that's why i didn't post this problem
we have had this problem from day one whit other Daw even PT won't see it if you don't do this.
some have had to be return.
I still used it . all daw can have this problem when the OS's don't let go of your Audio interface's
of all type's same thing go's for your vst's that used your interface IO's i found here .
I hope this help's.
syst' tec
ex BC eng'
DMS;DS;syst tec. world wide custom computer l
we like we used we play: Have fun not problem :mrgreen:
popajoe
Old 03-24-2014, 06:13 PM
Hi' here are some new setting http://duc.avid.com/showthread.php?t=338436 i will put them here ok
Old 11-28-2014, 12:02 PM
jaymusica jaymusica is offline
Hello everyone,
I am having similar issues with my midi controller when working with my pt 11.
When trying to go into Midi Studio (pro tools 11.0.1) to add my axiom 25 midi controller device, the following message displays:
"Audio MIDI Setup couldn’t open the MIDI Server so you can’t view or edit your MIDI configurations.
If you recently installed a new MIDI driver, try uninstalling it and then open Audio MIDI Setup again. If Audio MIDI Setup works correctly after that, contact the driver’s manufacturer for further support."
My midi controller works perfectly fine on my PT 9.0.6 and according to m-audio/axiom 25, no drivers are required (I could be wrong). Without the ability to add my device, my pro tools 11 is collecting dust at this point.
thank you for any help you may provide
Old 12-02-2014, 12:00 AM
www.youtube.com/watch?v=xOeqgw61VcE. try this .we are looking at this and will get back also try new PT 11.3/CHECK device manger sound,video and game controllers too make sure its using the right diver for it.
www.youtube.com/watch?v=6q8SrAdK8os if you need more call the candy store SW.
www.youtube.com/watch?v=vGnsQL0l18c
fix for can't find AUDIO device/ Controller/ personality popajoe Windows 19 09-07-2014 05:13 AM
Mbox3 controller personality AndreN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-15-2013 01:05 PM
Pro Tools cannot find M-Audio device riffmachine Pro Tools M-Powered (Win) 2 10-25-2007 12:05 AM
Where on site can i find the command 8 personality crizdee Pro Tools TDM Systems (Mac) 2 04-06-2005 12:26 PM
please where can i find midi controller personality bow Digidesign Hardware & Software 0 01-01-2001 02:21 AM
