Issues with Soundtoys speed
When processing clips with sound toys speed with the trimmer/timestretch tool, the audio renders out of sync.
I was guessing maybe it has something to do with the new handles feature, but not sure how to set the handles when it is set as the default time stretch plugin for the trimmer tool.
do you think the bass is taking away from my vocals? |
Re: Issues with Soundtoys speed
SPEED is completely screwy on my Pro Tools 10 system, it works perfectly in 8 and 9. Occasionally it will work, but mostly it spits out silent regions, or half of the original signal, half silent, etc.
I couldn't figure out a solution so I just stopped using it. I considered keeping another partition with PT 9 installed just so I could use Speed occasionally, but haven't gotten around to it. I haven't demoed it yet but maybe this could be a viable replacement? http://products.zplane.de/index.php?page=elastiquepitch
HD Native - Apogee Symphony I/O Mac Pro 6 core 3.33 Westmere 16 GB of RAM PTHD 10.2 OSX 10.7.5 |
Unfortunately I'm using it for just the time stretching function usually, when editing I jump between all the time stretch algorithms depending on what is most transparent for any edits that require time stretching.
Speed often sounds the best on acoustics, and the new system I'm working on doesn't have x-form which works well sometimes as well...
Same here. Spits out silent regions... Avid?? Soundtoys?
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
I emailed Soundtoys directly when I first discovered the issue and never got a response.
I've been dealing with this same issue as well. It's spitting out silent regions.
And another thing for me, I thought it might be because I needed to update the bundle to be compatible with 10, so I just recently updated to ver. 4 on the whole bundle. Everything else worked fine but Speed doesn't seem to have updated. If I go to the .dpm file in the plugins folder it says ver. 4, but when I click on the actual plugin in a session, it still says ver. 3. I've been going back and forth with Soundtoys about this for about a week now, and they've basically given up. He says he's been trying to recreate the problem on his machine and it works perfectly. I see this thread is a couple months old by now. Anybody come up with any fixes by now? My only workaround was to end up using the ProTools pitch-shifter which doesn't work as well, in my opinion.
iMac 21.5" (2017) Intel Core i7 3.6GHz, 1TB SSD, 32GB RAM PreSonus Quantum 2 interface Mac OSX 10.15.6 Catalina 1 G-Drive Pro 4 TB 2 G-Drive 6 TB ProTools 2021.3.1 Melodyne 5 Soundtoys Bundle 5.3.2 Omnisphere 2.6.2 Massey L2007 Superior Drummer 2.3.2 Komplete 13 Ultimate |
Soundtoys just released an update (4.1.6). I don't know if this fix these things, but I though you may try this. You can download it, from your account.
Here's the info.
my blog:Tamas Dragon |
I saw that. Just got it in an email today. I am definitely gonna check it out. It's funny timing, because I was corresponding with the guy literally just today when he told me he was pretty much out of ideas. That's why I came here to you guys.
When I get a chance to update it (probably tomorrow), I'll let you guys know if it helps or not.
Installing the update now to test Speed ...
Ok it's still not working ... but it seems to be able to process more of a region before it goes to silence. I'm probably just imagining that.
It's a shame because Speed was such a cool sounding tool for detuning tracks, it sounds like nothing else!
Speed issues (please help) | Gehah | Pro Tools 9 | 4 | 03-12-2014 01:44 PM |
FS: Soundtoys Speed V4, Autotune EVO TDM, Antares Avox II | Phil Pelissier | Buy & Sell | 1 | 11-24-2012 06:08 PM |
Soundtoys Echoboy issues - Native on HDX | SHIRK | Pro Tools HDX & HD Native Systems (Mac) | 1 | 10-08-2012 02:21 PM |
using soundtoys' speed instead of digi's TCEX | req06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-06-2006 04:04 PM |
Serato Pitch 'n Time vs/Soundtoys Speed | Compression Records | Pro Tools TDM Systems (Mac) | 9 | 05-08-2005 02:02 PM |
