Old 03-29-2011, 02:37 PM
stevesound stevesound is offline
Default better performance from 7 cores than 15 cores?
Hi.
just wondering if anyone can tell me why ProTools 9.0.2 runs best on my mac when I use 7 out of 16 cores? I tried lots of different settings (DAE, etc) and kept going between 14-16 cores but was overrun with crashes and DAE errors, but when I went down to 7 cores everything started running smoothly. Does Protools only run off 1 of the processors?
Prism Orpheus, PT 11, Mac 2x2.26GHz QuadCore Intel Xeon, 16g ram
Outboard - ADesign, Chandler, RetroDesign, Roland.
Old 03-29-2011, 06:10 PM
lexaudio lexaudio is offline
Default Re: better performance from 7 cores than 15 cores?
I assume when you say 16 it is hyperthreaded.
Probably because PT isn't coded for it.
You really only have 8 physical cores.
Old 03-29-2011, 08:17 PM
SolutionRoom SolutionRoom is offline
Or 12. My 8 Core runs without a single hiccup set at 6 cores. At 8 cores, it pukes randomly with a CPU overload error. No more. But, to answer your question... I do not know why that is, other than assuming that PT is using all the cores and leaves not enough processing power for other common Mac OSX tasks. My guess. Worth maybe 2 cents.
Old 03-30-2011, 11:41 AM
thanks for the answers! Was just wondering if there was a problem or something, good to hear it's a common thing.
Old 03-30-2011, 11:48 AM
Dism Dism is offline
There are a lot of reasons... but that isn't one. Pro Tools has been designed to handle all logical cores... physical or virtual.
It's not that Pro Tools can't handle them, it's more likely that you have a lot of background resources going on. Running other software in the background, running ReWire or running certain plugins that have dedicated resources outside of Pro Tools can all be factors.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Performance of Pro Tools in multi cores seems the same as in single core whsi Windows 5 02-10-2014 08:58 PM
Problems when using all 4 cores vs. 3 cores hopelessennui macOS 1 02-03-2012 06:54 AM
Mac Octo 2.26: Almost no difference between 2 Cores and 8 Cores Hive Guy macOS 8 05-10-2011 11:05 PM
using 7 cores instead of 8 stevedresser83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-08-2010 03:00 PM
for those of you that want 8 cores Craig F Pro Tools TDM Systems (Mac) 0 04-04-2007 12:00 PM
