Old 08-14-2010, 02:14 AM
ChrisSimon ChrisSimon is offline
Default Problems with MIDI Sustain Pedal while recording
I know, thatīs a problem, which is known for a lot of guys:
While playing along MIDI Input from a controller (masterkeyboard) works fine... While recording, the sustain pedal events will be released by random - impossible to play piano parts or something where you use Sustain pedal...
Itīs also on HD Systems, not just on native...
Every "workaround" with MIDI thru Instrument, check of the pedal (!!!) failed... still the same shxx as months ago....
Digi, itīs nice to see new features in the past like MIDI Editor etc, which is fine, BUT, why donīt get rid of these errors, which are important for "real musicians"????
Unbelievable!!
Chris
Old 08-14-2010, 02:43 PM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: Problems with MIDI Sustain Pedal while recording
Unbelievable!!
Chris
same here. Sometimes/ randomly sustain pedal releases "inside" PT-HD without relasing it in "RealLife".
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 08-14-2010, 03:25 PM
loosestones loosestones is offline
I get this too, the sustain also usually screws up when I'm punching in, or quantizing as well.
Old 08-14-2010, 06:08 PM
Steve@ZooWest Steve@ZooWest is offline
+1
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 08-14-2010, 10:47 PM
Dizzi45Z Dizzi45Z is offline
I see this a ton with Play's Virtual Instrument.
However, with Synthogy Ivory, I don't ever see this which makes me wonder if this is specific to certain Virtual Instruments.
When doing punch ins, I always have the pedal lane in view. It is critical that you punch in when the pedal is up (controller data is on the bottom of the Sustain Lane). Otherwise it will sustain the punch in until they press down and back up again on the pedal.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 08-15-2010, 01:38 AM
Itīs really on both, virtual instruments AND "real" hardware stuff....
And , what drives me mad.....we get new stuff on and on.....but the basic problems, which are really on the roots, worked better on ATARI in early days... Hope, that anyone of DIGI/AVID read this..... The standard in Recording programs with such a big....itīs unbelievable!!!! Since years!!!!!!
Old 08-15-2010, 01:49 AM
tonwurm's Avatar
tonwurm tonwurm is offline
same here, itīs independent from which instrument or VI is used, or which midi-controller is played (Yamaha CP-33, SY77) and it occurs only during recording
it seems that when the keys are released directly (in a very short time) after pressing the sustain pedal, then this issue occurs. I have this problem generally only with piano parts, playing many notes and making active use of the sustain pedal
maybe PT treats incoming midi-control events in an other way than note events (during recording), giving note events priority over controller events. if this was the case then it can happen that a sustain event is sent a little too late - only a thought...
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 08-15-2010, 05:37 AM
Same here. No matter if use any external Synth or VI - just occurs once a while
Cheers, STeff
Old 08-15-2010, 12:27 PM
Audiofarm Audiofarm is offline
+1
I thought it was my good ol A-80 that is ready to be retired.
Old 08-17-2010, 08:02 AM
No reaction, DIGI, sorry, AVID??
sustain pedal problems in 6.4LE tromostheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-29-2009 09:24 AM
PT8, Sustain pedal, velocity problems while recording ChrisSimon MIDI 1 08-20-2009 05:23 PM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 12:56 AM
Piano sustain pedal in recording Help!! Zownd Tips & Tricks 9 04-05-2004 02:21 PM
Sustain Pedal in Midi recording in PT LE Arya44 Tips & Tricks 1 11-09-2003 11:25 PM
