Old 01-09-2010, 11:55 PM
pianosound pianosound is offline
Default Thanks Benoni,,,,,,,,,,,
Benoni,,,,(and everyone else definitely),,,,,, sure appreciate your helping me get going, and get up and running with W7!!! Except for the freeze that a few of us are dealing with,,, I'm almost positive that I'm going to stick with it. By the way,,, I guess that I can just connect my old XP HDD by itself and run the W7 disk to reformat it,,,,, right? Or will I need one of those USB cases to plug the SATA drive into, and do the reformat with it? How have any of you done this in the past??? Thanks ,,,,,,,,,,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Old 01-10-2010, 04:27 AM
JonnyGinese JonnyGinese is offline
Default Re: Thanks Benoni,,,,,,,,,,,
If you need to use the SATA drive for your system drive for W7.. then Yes.. just plug it in your PC via SATA and go through the setup...when it shows you your drive options.. delete the partition info on the SATA dive you plugged in and continue the install on that drive.
If you don't need to use the SATA drive for your system Drive... and you already have W7 running on another drive.. Then Plug the SATA drive in.. once you get into windows.. go to Start > Computer > Right Click the Drive you plugged in > Format. It will Delete everything and make the dive fresh and ready for back-ups or Audio or Samples.
If you are doing a Fresh install on W7 on your Drive.. i would recommend un plugging any other Drives in the PC while you are doing this to Ensure you don't make a mistake by formating your Audio drive because it was the same size or something.
-AIM: RS Recordings -Skype: RSRecords
| Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r |
Studio Site: Red Sneaker Records
BENONI If You're Here lspaulsp Eleven Rack 2 05-29-2013 05:03 AM
Matching Guitar Sounds - Att: Benoni Jerry S Eleven Rack 25 09-29-2010 02:02 PM
Benoni and TOM@METRO: Best Serrogate Please bootybandit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-09-2010 11:25 AM
Benoni,sitting on a fence, PLEASE HELP!? pianosound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-02-2010 02:18 PM
