BUG: QT playback stops after Audio import in LE
Hi all,
Does anyone know how to fix this without having to quit PT+reopen ? Mac, 8core, 6gB RAM, PTLE 8.0.3pr (would also do it in 8.0.1), 29.97DF DV stream that I'm watching on the DESKTOP, not externally via Canopus. I'm happily mixing away and sometimes need to import SFX from another drive: If I can, I'll drop them into the PT icon on the dock, I get a progress bar and they show up in the audio files window. Sometimes, however, I'll get an assertion error and the only way to bring them in is via the AUDIO IMPORT window. Problem is, when I have to do it this way (the file is imported fine), the QT almost always stops working. It'll locate along with PT, but will not playback anymore. In HD, I would toggle the VIDEO OUT FIREWIRE menu and things would be fine, but at home I'm just watching the video on the desktop and I don't have such option, so I can only quit+reboot. Any ideas ?? Thanks, Benny. |
Re: BUG: QT playback stops after Audio import in LE
from the sound of the post, you are probably using Snow Leopard... I think that the dock assignment of files is still buggy, many people reporting issues. I'd just stick to the standard Audio Import option.
Also, you might want to check out Soundminer too. Great program for spotting effects from other media.
NuanceTone.com |
My problem unfortunately happens when I use the standard import option, dropping onto the app on the dock is just a faster way of working.
I use Soundminer at work and it's great, but I don't need it for home. This is, btw, a bug that is present in both LE+HD. |
Import audio, playback issue | joeystats | Windows | 3 | 04-30-2012 09:53 AM |
import cd audio really slow playback/scroll | simon mog | macOS | 13 | 09-01-2011 03:42 AM |
No playback after I import audio... | luisam | Pro Tools 9 | 0 | 03-24-2011 08:08 PM |
Audio playback stops during bounce | matthew.sawicki | Pro Tools TDM Systems (Mac) | 2 | 08-20-2010 02:26 PM |
audio playback stops when recording and playing back | cnote | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-27-2007 03:09 AM |
