Old 10-18-2016, 07:58 AM
cheney5 cheney5 is offline
Default Automation Ignored In IZOTOPE Dial Denoiser
Hi All,
I am automating the reduction amount in the Izotope Dialogue Denoiser (on stereo audio track) for each clip but Pro Tools 12.5.2 HD is ignoring the changes.
I have the track in touch and have tried read too. Still the same. The fader on the plugin goes up and the audio doesn't change at all.
The only way to fix the issue is to automate the bypass to flick off and on quickly within the new parameter setting.
Any had Pro Tools ignore their automation?
I'm on a 2016 iMac running El Cap. However I have just tried it on a 2012 Mac Pro, El Cap & 12.5 HD and got the same results.
Any advice would be gratefully received.
Old 10-18-2016, 09:14 AM
quadraphonics quadraphonics is offline
Default Re: Automation Ignored In IZOTOPE Dial Denoiser
While I haven't seen this issue, a number of 3rd party plug in manufactures have seen issues with automation in Pro Tools 12.5.x - The Cargo Cult being the most notable.
The solutions seem to be to either revert to 12.4.x or upgrade to 12.6.x
Good luck.
Randall
Originally Posted by cheney5 View Post
Hi All,
Old 10-18-2016, 08:40 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
I've had automation issues with Denoiser with PT10.
My solution is to always use it in Manual mode. Auto mode seems to bug out the automation.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 10-19-2016, 07:38 AM
Reckless Erik Reckless Erik is offline
Agreed. In auto mode the plugin is always changing the parameters and therefore always writing automation. PITA. Also noticed that control command clicking on parameters in iZotope Final mix does not bring up the automation lane in the timeline. Another PITA. Could this also be a PT version issue?
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 10-19-2016, 07:59 AM
I've not managed to go back to the studio and upgrade to test yet. That does make sense that the continual automation causes an issue. But if 'reduction' is the only parameter in automate I kinda hoped it would be okay.
Old 10-19-2016, 11:37 AM
onosendai onosendai is offline
I've encountered this inability to use the automation lane shortcut with Nugen and Mcdsp plugins as well. I think it has something to do with developer implementation and not Pro tools. It is also for this reason that I sometimes just grab for Avid's stock plugins, since they are faster and more solid automation-wise especially when you are not using a controller.
i7 5820K, 32GB | Windows 10 Pro, PT 2021.10 Ultimate | RME FF802
Old 10-19-2016, 01:22 PM
ZigZagZig ZigZagZig is offline
hello hello
just deactivate the six threshold automations and it should work fine. (see attached pic)
also, if you do not disable these, your undo history will grow with every pass, because in automatic mode this will write lots of control value changes.
cheers
Mac Pro 14,8 M2Ultra 192GB RAM - OS X 13.6.3 - PT HDn 2023.09 Thunderbolt - HD I/O + RedNet HD32R + SYNC HD - Blackmagic SDI 4K - Mutec MC-3.2 Smart Clock HD - BSS Soundweb - Alcons CRMSmkII - ATMOS equipped Edit & Premix-Room
HTML code is On
iZotope RX4 Denoiser behavior different in PT10 vs 11/12 fsrenduro AAX Plug-ins 8 07-15-2015 05:40 PM
iZotope RX4 Adv and automation in PT10 tvjorg Post - Surround - Video 5 12-08-2014 10:05 AM
32Bit Dial vs 24 Bit Dial kd_special Post - Surround - Video 9 05-27-2014 12:06 PM
Denoiser??? threesixty Tips & Tricks 4 01-10-2003 07:25 AM
Plugin like Behringer Denoiser ? Henry's Big BoyzToyz Tips & Tricks 0 12-06-2001 09:09 AM
