Migration Pro tools III -> 24mix
Hi folks, ;-)
I'm actualy using a nice legacy refurbished Pro tools III tdm pci on a 9600 PPC with G4 sonnet 800 mhz one card i/o and 3 dsp farm everything run ok. My question is : is there a easy way to migrated and upgrade to a 24bits mix or mixplus system ? I though it was possible to do this by just swap my i/o card PTIII and replace with an used mix core card from a old mix system. is it possible ? or m'i wrong? I don't want to go PTLE, Because of the awful lantency. Thanks for your answer and sorry for my poor english.;-)
Owner of www.studio-up.be Pro Tools 2020.11 HDX Sonnet Thunderbolt 3 Rack enclosure with a Mac Mini 2020 I7 64Gb of ram And Avid Dad Mtrx Studio … |
ouou Migration Pro tools III -> 24mix
Oyé ! Help me Please
Is there someone here ? Thanks DIGIIIII
Re: ouou Migration Pro tools III -> 24mix
I think its posible. But you would still need a 20 or 24 bit interface.
Also you would have to check if the mix card you buy is compatible with your farm cards. If posible, the best thing to do would be to ask the seller to bring the card to your place and test it. I think it should work right away with the software you have installed, but im not certain. I want to do the same upgrade as you when I find a mix or d24 card, so I will be interested to hear your results. Good luck and get back. Pepo |
Re: Migration Pro tools III -> 24mix
There is two ways to do this, And yes you will replace the Disk I/O card in the system, One way is to find a D-24 card to replace the Disk I/O card, You can then add a Mix Farm to the system to make it a Mix configuration..
The other is to add a Mix Core card and Mix Farms to make a Mix+ configuration.. Both of these setups will still work with the 3 DSP Farms you have now, But you will have to also add a SCSI card to connect your hard drives that you will be recording to, So you will start running out of PCI slots rather quickly.. Here is some compatibility docs from the archives: Pro Tools|24 Systems with Pro Tools 5 for Mac OS 9 Requirements Pro Tools|24 MIX Systems for Mac OS 9 Requirements |
Many Thanks for your answer Pepo and milesofwire !!!
You are saying that I need an extra Scsi card, but what about, if instead I prefer using internal Ide disk drive controled with a sonnet Ata 100 ?(I'm still using 9600 with upgrade G4 800mhz) digi say : *IDE/ATA support is limited to Powermac G3 or later models, which include a built-in ATA bus. Pre-G3 models that only shipped with SCSI have not been tested with add-on ATA/IDE controller cards. An why must i have an older d24 card ? is the mix core card not enough in order to build a 24mix system? So to be clear my system would be (I'm not shure for card order) 1Mix core 2dsp1 3dsp2 4dsp3 5ideaTA100 6ati 7000 radeon If it works i'be glad because it s hard here in Belgium to find a good working expansion chassis !! If I find a mix core card I let you know my experience Pepo !!! Have a nice day
Correct, IDE add on cards were not tested, Try it, it may work..
And yes a Mix core by itself will work fine with the setup you listed |
I don't think there will be a problem if just adding a Mix Core card to your DSP farms. The compatability issue with DSP farms is PCI bus and OS related, not between Digi's own cards. If the DSP cards work now they will work when you add the core card. The difference between the the Mix Core/Farm and the DSP cards is the number and type of chips on the card. Some newer plugs require the chips only available on the Mix cards. I just bought a Core and Farm myself, so I'm kinda like you, just getting started. I am running on an Intel P4 with WinXP, although I do have a 9600/G3-400 here. You might try Alto Music in New York state, they sell tested Mix Core cards for something like $650US from the store and their shipping is reasonable, I got both my cards there. Good Luck.
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
Help bring Pro Tools back to life after migration assistant!!! | hugoleitao | Pro Tools TDM Systems (Mac) | 3 | 10-04-2012 01:53 AM |
LE to HD migration.. | m4ca | Pro Tools TDM Systems (Mac) | 0 | 03-03-2009 01:09 AM |
convert Pro Tools 6.1 TDM 24MIX from MAC to Windows | rmeuchel | Pro Tools TDM Systems (Win) | 1 | 11-26-2007 12:48 PM |
convert Pro Tools 6.1 TDM 24MIX from MAC to Windows | rmeuchel | Pro Tools TDM Systems (Mac) | 0 | 11-26-2007 09:16 AM |
blue (blank) crossfade error - Pro Tools 6.1 on 24Mix | rmeuchel | Pro Tools TDM Systems (Mac) | 0 | 04-05-2007 06:53 PM |
