Old 07-26-2009, 07:15 AM
WATYF WATYF is offline
Default Pro Tools freezes up while loading plug-ins....
I had a hard drive crash a week or two ago... I keep regular backups of my drives, so no big deal. I got the new drive, restored the image to the drive and fired it back up. One of the first things I did was open Pro Tools and run a session I had recently worked on. Everything ran fine.
A week or so later, I go to open Pro Tools to track something... it freezes up during the Plugin initialization. It stopped while loading the Waves shells (I have several Waves plugins). I figured maybe the authorization for Waves got messed up after the crash, so I removed all plugins from the DAE/Plugins folder and tried opening Pro Tools. It opened just fine.
So I added in everything back in except the Waves shells, but it still locked up while loading plug ins. So I tried a complete reinstall. I ran the Pro Tools remover (for version 8). I uninstalled my Waves plugins. Then I reinstalled just Pro Tools. Tried to open it... no dice. It locked up while trying to load Structure.
So... why would Pro Tools keep failing while loading plugins?
WATYF
Old 07-26-2009, 08:44 AM
critza critza is offline
Default Re: Pro Tools freezes up while loading plug-ins....
WATYF
I have no direct answer for you, but i would try:
1 Update PACE drivers
2 When you reinstalled PT did you follow all the general troubleshootingtips?
3 Start the project holding down the Shift-key so it opens with all the plugins deactivated, then activate a few save a backup session somewhere and restart, until you find out which of the plugins that are messing with you.
Good Luck!
Old 07-26-2009, 02:25 PM
1) I already got the latest PACE drivers.
2) I ran the troubleshooting steps when I built the machine.
3) It isn't a session that's failing... it's Pro Tools itself. I can't even get to the part where you try to open a session.
WATYF
Old 07-26-2009, 03:17 PM
JMS40 JMS40 is offline
Download the Pro Tools Tech Support Folder and generate a complete plugin list. Copy/paste it here for the guru's to have a gander at.
Old 07-26-2009, 04:20 PM
I downloaded that, but don't see where it generates a plugin list. I ran the thing that says "Remove Plugin and toolkit warnings" and that appears to take some of the plugins out of the DAE\plugins folder and put them in the Plugins(unused) folder. Then I tried launching Pro Tools again... this time, it made it all the way through the load, but then gave me this error as soon as PT was loaded.
WATYF
Old 07-26-2009, 04:31 PM
danander11 danander11 is offline
Maybe this will help:
http://duc.digidesign.com/showthread...73#post1420273
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 07-26-2009, 05:28 PM
Originally Posted by danander11 View Post
OK. That solved the Divide by zero issue, but it still won't load when I have Structure in the plug in folder.
WATYF
Old 07-26-2009, 05:32 PM
And it's not just Structure... if I put Autotune (or Waves shells) in the plugins folder, it won't load either.
WATYF
Old 07-26-2009, 05:53 PM
Look for the Generate Version List option in the Tech Support Utility.
Creates a text file on the Desktop called “Pro Tools Version List” that lists the version number of the Pro Tools
application, all installed plug-ins, all installed Toolkit options and DigiTranslator 2.
Further, it would help to know a bit more about your system hardware. Might want to post a PC Wizard report from the same download.
What Digi hardware are you using?
Old 07-26-2009, 06:19 PM
TS LogFile Created Sun Jul 26 18:11:33 2009
Drive Letters Present:
CD
Windows Directory is:
C:\WINDOWS
SystemDirectory is:
C:\WINDOWS\system32
C:\Drive Specs:
Total Drive Space:
150029074432
bytes
Total Free Space:
14559289344
bytes
Available Free Space:
14559289344
bytes
A valid installation of Pro Tools was found at:
C:\Program Files\Digidesign\Pro Tools\ProToolsLE.exe
Version Number:
8.0.0.340
7. Advanced Menu... from main Non TDM
9. Main Menu... from Advanced
6. Generate Version List from main Non TDM
1. Remove Plug-In and Toolkit Warnings from main Non TDM
" Plug-Ins (Unused) " Directory already present
Created Directory:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\Plug-Ins (Unlicensed)\
Created Directory:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\Plug-Ins (Unlicensed)\Toolkits\
Successfully Transferred:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRChorus.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRChorus.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRChorus.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRChorus.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRDistortion.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRDistortion.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRDistortion.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRDistortion.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRDynamicDelay.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRDynamicDelay.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AirDynamicDelay.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AirDynamicDelay.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIREnhancer.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIREnhancer.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIREnhancer.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIREnhancer.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIREnsemble.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIREnsemble.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIREnsemble.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIREnsemble.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRFilterGate.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRFilterGate.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRFilterGate.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRFilterGate.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRFlanger.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRFlanger.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRFlanger.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRFlanger.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRFrequencyShifter.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRFrequencyShifter.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRFrequencyShifter.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRFrequencyShifter.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRFuzz-Wah.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRFuzz-Wah.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRFuzz-Wah.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRFuzz-Wah.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRKillEQ.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRKillEQ.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRKillEQ.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRKillEQ.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRLo-Fi.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRLo-Fi.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRLo-Fi.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRLo-Fi.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRMulti-Chorus.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRMulti-Chorus.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRMulti-Chorus.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRMulti-Chorus.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRMulti-Delay.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRMulti-Delay.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRMulti-Delay.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRMulti-Delay.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRNon-LinearReverb.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRNon-LinearReverb.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRNon-LinearReverb.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRNon-LinearReverb.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRPhaser.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRPhaser.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRPhaser.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRPhaser.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRReverb.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRReverb.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRReverb.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRReverb.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRSpringReverb.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRSpringReverb.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRSpringReverb.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRSpringReverb.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRStereoWidth.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRStereoWidth.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRStereoWidth.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRStereoWidth.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRTalkbox.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRTalkbox.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRTalkbox.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRTalkbox.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRVintageFilter.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRVintageFilter.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\AIRVintageFilter.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\AIRVintageFilter.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\BF Essential Clip Remover.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\BF Essential Clip Remover.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\BF Essential Clip Remover.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\BF Essential Clip Remover.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\BF Essential Correlation.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\BF Essential Correlation.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\BF Essential Correlation.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\BF Essential Correlation.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\BF Essential Meter Bridge.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\BF Essential Meter Bridge.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\BF Essential Meter Bridge.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\BF Essential Meter Bridge.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\BF Essential Noise Meter.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\BF Essential Noise Meter.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\BF Essential Noise Meter.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\BF Essential Noise Meter.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\bombfactory BF76.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\bombfactory BF76.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\bombfactory BF76.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\bombfactory BF76.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Boom.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Boom.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Boom.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Boom.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Chorus.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Chorus.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Chorus.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Chorus.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Click.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Click.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Click.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Click.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\D-Verb.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\D-Verb.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\D-Verb.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\D-Verb.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\DB-33.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\DB-33.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\DB-33.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\DB-33.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\DigiReWire.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\DigiReWire.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\DigiReWire.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\DigiReWire.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Dither.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Dither.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Dither.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Dither.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Dynamics III.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Dynamics III.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Dynamics III.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Dynamics III.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Elastic Audio.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Elastic Audio.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Elastic Audio.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Elastic Audio.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Eleven Free.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Eleven Free.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Eleven Free.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Eleven Free.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\EQ III.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\EQ III.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\EQ III.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\EQ III.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Flanger.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Flanger.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Flanger.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Flanger.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Invert-Duplicate.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Invert-Duplicate.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Invert-Duplicate.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Invert-Duplicate.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\iZotope_Radius_Win32.dll
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\iZotope_Radius_Win32.dll
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\LoFi.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\LoFi.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\LoFi.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\LoFi.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Maxim.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Maxim.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Maxim.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Maxim.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\MiniGrand.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\MiniGrand.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\MiniGrand.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\MiniGrand.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Mod Delay II.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Mod Delay II.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Mod Delay II.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Mod Delay II.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Multi-Tap Delay.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Multi-Tap Delay.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Multi-Tap Delay.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Multi-Tap Delay.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Normalize-Gain Change.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Normalize-Gain Change.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Normalize-Gain Change.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Normalize-Gain Change.dpm.rsr
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Ping-Pong Delay.dpm
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Ping-Pong Delay.dpm
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\Ping-Pong Delay.dpm.rsr
To:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins (Unused)\\Ping-Pong Delay.dpm.rsr
Pro Tools 9.0.6 freezes when loading eargizzle macOS 12 06-28-2013 03:59 PM
Computer Freezes while loading Pro Tools GSG Pro Tools TDM Systems (Mac) 1 10-27-2011 07:19 AM
After 9.0.3 upgrade Pro Tools Freezes Loading Dekazman Windows 1 06-23-2011 03:26 AM
Help!! Pro Tools freezes when loading DAE options DEATHMAN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-10-2009 12:12 AM
Pro Tools LE freezes when loading Squishy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-04-2008 08:40 PM
