6.9 Automation Send Level Bug
When in trim mode with the send level unarmed, adjusting a send now results in a level offset from absolute zero! For example, if send A is set to let's say -19 and I adjust it by -3 while rolling in Fader trim/touch, I get an absolute level of not -21 as expected but -3!!. The send level has no pevious automation breakpoints and I do not wish to automate the send. I just want to adjust it's overall static level. Now I have to stop, adjust the level, play, listen to it, stop, re-adjust and so on.
The error in question happens no matter which way I adjust the send level. I use a Control 24 and it happens using rotary encoders, flipped faders or the mouse. Check out the odd behaviour in the send levels after you undo the errant send adjust. Has anybody else seen this? |
copy a send (w/send level intact) from 1 to 30 audio tracks? | MixerGuy | Pro Tools TDM Systems (Mac) | 3 | 12-30-2007 03:20 PM |
7.3.1 Send level meter just mirrors track level | bashville | Pro Tools TDM Systems (Mac) | 11 | 01-16-2007 08:19 PM |
value of send level lost in pt7 cs2 | m4tune | Pro Tools TDM Systems (Mac) | 0 | 02-20-2006 07:30 AM |
Changing default send level? | Great Divide Studios | Tips & Tricks | 4 | 03-26-2002 11:03 AM |
channel level mirrored in send level meter | daveh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-01-2001 01:32 AM |
