Old 08-24-2010, 12:00 PM
Stig Eliassen's Avatar
Default What's stored with PT preferences?
Any docs on this subject?
Old 08-24-2010, 12:24 PM
Dism Dism is offline
Default Re: What's stored with PT preferences?
It's pretty much everything you expect. I don't know if there are any docs... but just about everything that gets saved for the next session. I/O, track colours, window arrangements, peripherals, setup preferences, etc...
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 08-24-2010, 12:41 PM
I was hoping that there could be a list somewhere. The reason being that I have to trash the prefs often to keep the D-Command working properly, and there's always something I've forgotten to set up the way I want before I make a backup of the prefs.
Old 08-24-2010, 01:28 PM
Hanswurstlsepp Hanswurstlsepp is offline
Donno if that helps you, but in addition to the Prefs & Database helper.app I take screenshots from time to time.
I/O-Setup (Busses, Output, Input)
The 4 Peripheral-tabs
PT-Pref-tabs (7 pages/tabs)
What's definetely stored, too are the user buttons of D-command and the ConsolePrefs/Operations and some more stuff.
For those, I'm using my camera
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 08-24-2010, 02:06 PM
GS-DK GS-DK is offline
Same here - a bit old-fashioned, but it gets the job done.....
Old 08-24-2010, 02:12 PM
Carl Kolchak Carl Kolchak is offline
You could get your prefs set up as you like them to be, then copy the folder to a safe location.
Next time you have to trash the prefs, replace the new prefs folder with a copy of your back-up.
Old 08-24-2010, 02:22 PM
Oliver M Oliver M is offline
Yep, this is what I do. Only difference is that I use a couple of AppleScripts to backup and restore the prefs to automate these procedures. Of course this is still no real answer to the OP's question.
I do not think that there is a list so you gotta find out yourself. Make changes of your settings and after each change check for modification dates of the following files:
Pro Tools v8.0 Preferences
DigiSetup.OSX
com.digidesign.ProToolsHD.plist
Oliver
Old 08-24-2010, 02:56 PM
Thanks for the tips. I'll ponder on this a bit.
Old 08-24-2010, 08:31 PM
JC925602 JC925602 is offline
Originally Posted by Oliver M View Post
...Make changes of your settings and after each change check for modification dates of the following files:
DigiSetup.OSX
Oliver
The ProTools Preferences file is only change when you quit ProTools. The process seems to be:
1- Delete the old file
2- create a brand new file
And some prefs are also saved with the session file and will overwrite your own pref when you open it.
JC
Old 08-25-2010, 03:35 AM
THANK YOU! I've had a feeling about this, but since I never tested this meticulously I didn't know.
Installer, where is it stored? j.thomas Windows 3 10-16-2011 01:24 PM
Where are templtaes stored? stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-14-2010 12:46 PM
Where are ICON preferences stored? macaholic ICON & C|24 1 09-12-2008 06:48 PM
Preferences is not stored Raggi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-24-2007 08:40 AM
USD settings not stored PHead14006 Pro Tools TDM Systems (Mac) 0 08-10-2001 09:22 AM
