"There are more RTAS tracks than avail voices??
Hi, I am new to HD, and when I load even just 8 tracks, I get the message stating there are more active tracks than RTAS-enabled voices, so tracks don't play. It does this @ 192 and 96k. I have the core card connected properly and can get sound out sources going through channels 1-6. I'm on a new Dell XPS 8100 with i7 and 8gb of ram, so what could be the problem? Running no plugs yet, just trying to get started here...
Also my command 8 will control the volume knobs on the screen, but shows as "Command 8 Offline" It works perfectly when I use it w/ my LE system. Any recommendations to get this to sync correctly? The Peripherals are set correctly... Any advice would be greatly appreciated. Thanks, Rich |
Re: "There are more RTAS tracks than avail voices??
Playback Engine settings - increase the number of voices...
Manual is pretty good |
Do HDX cards steal voices for using "Native" on a AUX | soundeq | Pro Tools 10 | 8 | 11-30-2011 06:59 PM |
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" | xfarre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-22-2011 07:37 AM |
RTAS on Aux using 4 voices? | KingFish | Pro Tools TDM Systems (Mac) | 2 | 01-31-2009 07:13 AM |
48 tracks still not avail after installing MPTK | MotifMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-18-2008 07:58 AM |
Tracks and "Voices" | one track minds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-21-2003 06:31 AM |
