Old 08-04-2005, 12:01 AM
dobby12 dobby12 is offline
Default Best/easiest way to generate a click for Mix+
Hi, I was wondering what the easiest way to generate a click would be for Pro Tools 5.1 Mix+... I've just been using the Click plugin in my LE rig, but I'm doing a session in 5.1 that needs a click. I guess I could just hook up a drum machine, but that would take up an input and I'd like to avoid that if possible. Any suggestions?
Old 08-04-2005, 12:28 AM
whosmatt whosmatt is offline
Default Re: Best/easiest way to generate a click for Mix+
I always just used a sample (or a couple of them) and arranged them on the grid and then duplicated as much as needed. It's easy enough to do, but is a pain if you change the tempo. An alternate way is of course to make a midi track to play a drum machine or sampler and print it back, that way you don't use up an input... if you have a console you could of course use the drum machine via midi and just output it through the console and not use up an input or output for the click. and midi follows tempo changes, unlike samples on the grid. I have tried using kontakt but the midi timing via the IAC bus was terrible.
moving up to 6.4.1 not only gets you the click plugin, but the ability to use Reason or another software sampler via rewire to play a more elaborate click track. in my experience, the midi timing is MUCH better in OSX than in OS9, at least when it comes to software instruments.
matt
Anyone Know how to Generate a Click Track in PT 5.1? fooloof Tips & Tricks 9 04-27-2012 01:19 PM
Easiest way to quantize/Build a tempo map from drums not to a click? brandobean Tips & Tricks 5 02-15-2012 05:29 AM
best way to generate click... Anibal Pro Tools TDM Systems (Mac) 13 08-15-2005 06:27 AM
Easiest way to get a click Paul_m Tips & Tricks 7 01-29-2003 10:02 AM
USD generate TC DannyVanSpreuwel Pro Tools TDM Systems (Mac) 6 11-11-2000 09:25 AM
