Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
  #21
Old 02-13-2020, 09:21 AM
reichman's Avatar
reichman reichman is offline
Default Re: Mbox family driver support for Mac OS Catalina
Originally Posted by Matt Madhouse View Post
Hi everybody,
A week ago I updated my Mac to Catalina, and my audio interface is the Mbox 3 Pro.
To be honest everything work just fine, no issues at all so far.
So, if you have the Mbox 3 Pro and thinking of updating the Mac to Catalina, do a backup and give it a go! It should be working, and if it doesn't you can simply use Time Machine.
Again, I'm working right now on my PT HD 2019, iMac 2017, Catalina 10.15.3 using Avid Mbox 3 Pro... All good!
This is interesting. I wonder if because you updated (instead of a clean install), the underlying driver continued to function. Can you launch the MBox Pro application? I doubt you can, which would make adjusting parameters impossible. Post again with more info!
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
  #22
Old 02-13-2020, 09:27 AM
7189171 7189171 is offline
my driver was worked and I updated to a new macos catalina, now it says that the drivers are not supported by the system and contact the device supplier
  #23
Old 02-15-2020, 08:18 AM
Matt Madhouse Matt Madhouse is offline
You can believe it or not, but I am working using the Mbox 3 pro and Catalina, and it works! I don's see the point of giving you a fake information.
  #24
Old 02-15-2020, 08:23 AM
Ok, so,
yes: I'm not able to open the Mbox 3 pro application, and
yes: I updated instead of doing a clean install.
Apart from the Mbox app that doesn't work, all the rest works perfectly, so at least I don't have to buy a new audio interface right now.
Excessive Processor Usage and Temperature: Avid 002 & 003 Family Driver Mike Harrison macOS 10 08-15-2014 03:54 PM
How to remove Avid Family 003 driver kmusic Pro Tools 11 6 11-06-2013 08:11 PM
Excessive Processor Usage: Avid 002 & 003 Family Driver Mike Harrison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-28-2013 03:14 PM
RIP 003 + Mbox 2 Family bootybandit Windows 8 03-18-2011 04:01 AM
To DIGI Support please, NO 003 and MBOX PRO in the same PC because new64 driver flautista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 12-21-2009 04:49 PM
