Old 09-18-2015, 11:34 AM
Arionas Arionas is offline
Default Pro Tools Control (for iPad) issue
Hi everyone,
before a month I downloaded the application for iPad to use with my Pro Tools 11.
I installed the EUCON and everything worked as expected.
Before some days I purchased the support plan and installed Pro Tools 12.2
Everything is fine with the DAW except that now, while the PT Control connects successfully with the daw and the transport functions work just fine, the mixer tracks appear on the iPad all the way down and unusable. Also don't appear the names at each track. I tried to reinstall EUCON but nothing changed. I'm on a mac OS X 10.10.5 system. Any idea?
Thanks in advanced,
Nikos
Old 09-18-2015, 11:45 AM
Bobogura Bobogura is offline
Default Re: Pro Tools Control (for iPad) issue
Have you installed the latest version of the iPad app?
I had similar problems before getting the latest.
Old 09-18-2015, 12:20 PM
It seems I have the latest version as doesn't appear any new update in the App Store folder.
Old 09-18-2015, 12:27 PM
Southsidemusic's Avatar
The latest is 1.0.4 and it didn't appear in my download notice either but as I wnt to the app store it said "update" and then everything worked again with Eucon 3.3.1 as thats needed aswell.
Check the app store.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-18-2015, 02:38 PM
I have already installed the same v1.0.4 (11 September).
Unfortunately it doesn't go for me... Probably something else is going wrong here. The latest thing I'd like to do is to reinstall Pro Tools... but I don't think is gonna solve the problem either. Anyway, thank you both for your answers.
I'll give up, I already spent many hours to get this app work.
Old 09-20-2015, 01:23 AM
Finally.... After reinstalling 2-3 times the EUCON app, everything worked just fine. I still don't know what had cause the issue.
Old 09-20-2015, 07:35 AM
john1192 john1192 is offline
good to hear .. i posted this in the other Forum for you as well .. http://avid.force.com/pkb/articles/e...tibility-Chart .. 10.10.5 not listed yet .. i thought maybe that was part of your issue but since you are good now .. probably not ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 09-20-2015, 09:17 AM
Just to notice that first appeared the names under the tracks and the track levels but not the pans. Were all they way left for both mono and stereo tracks. After restarting Pro Tools for one more time, everything came at normal.
Old 09-21-2015, 09:54 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Are you definitely running EuControl 3.3.1 with the latest version of Pro Tools | Control (v1.0.4)? This issue sounds like what we see when there is a version mismatch between EuControl and Pro Tools | Control.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 10-07-2015, 09:36 AM
Markrosoft Markrosoft is offline
I am having the same issue and the problem seems to be that there's no way for me to update to the most recent version of the app. The app is 1.0.1. There's no option to update. I've tried deleting it several times but all that's available is 1.0.1. I've tried searching on the computer on itunes but 1.0.4 is not available.
Any idea how I can get version 1.0.4 of the app??
(Right now all that works is the transport - the faders are all unlabeled, stuck all the way down, and with random Solo and record enabled buttons pressed).
New Avid Pro Tools Control for iPad nst7 Avid S1, S3, Dock and Control App 261 10-13-2015 12:33 PM
EuControl/Workstation 3.3 & Pro Tools | Control iPad app now available! Kyle Splittgerber Avid S1, S3, Dock and Control App 0 08-06-2015 02:59 PM
Can I control Pro Tools with an Ipad south89 macOS 4 04-05-2013 09:36 AM
Ipad V-control? The golfer Post - Surround - Video 23 11-16-2010 04:40 AM
