Old 05-27-2011, 04:19 PM
Oblivious74 Oblivious74 is offline
Default The current playback engine does not support a sample rate of 192k
When I try to open any of my sessions I get this message:
The current playback engine does not support a sample rate of 192kHz
I have a Mac Book Pro 10.6.7 running Snow Leopard, Pro Tools 9.0.3 (was hoping the update might fix this) and an M-Audio Profire 2626 interface. All of this was working fine until one day when I tried to open a session and that message popped up. I took my MacBook up to Guitar Center where I bought the equipment/software and plugged it into their Profire 2626 and it worked fine at a sample rate of 192kHz. So, I swapped out the interface. As soon as I got home I got the message again... so the only other variable was the cable which I also replaced. This problem was going on before the new Profire 2626 and after.
I emailed avid tech support and said if the problem was confined to only one session, import the tracks from that session to a new file and go from there. Unfortunately it is not confined to one session and now when I try to record a new session I only have the option for up to 96kHz.
Under the Mac Book Pro's System Preferences I have tried changing the Input/Output to just about every option and combination that is available including switching to Profire 2626 Multichannel for in/out and Pro Tools Aggregate I/O and combinations of them.
Has anyone run into this problem or know how to fix this problem? I am sure it is a setting issue somewhere. This message pops up regardless of whether I try to run Pro Tools with my Profire 2626 turned on or off. My settings on the profire have all active inputs selected; an internal sync source; and a sample rate of 192k Thanks in advance!
Old 05-27-2011, 06:00 PM
Question Re: The current playback engine does not support a sample rate of 192k
I have adjusted the settings for the system preferences, M-Audio Profire, restarted the computer, and tried to open pro tools a 20 times today... and this time it worked... and I have no idea why
Old 05-27-2011, 06:40 PM
Noiselab Noiselab is offline
Default Re: The current playback engine does not support a sample rate of 192k
I've seen this before when I've left the ProFire control panel set to the wrong sample rate. This is particularly true with the aggregate I/O settings.
NL
Old 06-01-2011, 07:08 PM
after i get the error I close PT, change the i/o settings in system configuration, open PT, close it again, then change them back to the Profire 2626 and open PT a 3rd time it works....
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 09:43 PM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
The Current Playback Engine Does Not Support a Sample Rate of 48Khz justus1900 Pro Tools 9 14 10-23-2012 01:45 PM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 03:21 AM
