Old 10-25-2007, 06:04 AM
Jala Jala is offline
Default Custom Faders Justify????
I am completely confused about custom faders. Not what to do with them but how to set them up. I do not get the "Justify" settings at all. Can you guys please explain this to me?
Old 10-25-2007, 12:15 PM
Drew Mazurek's Avatar
Default Re: Custom Faders Justify????
Let's say you've got a D Control with 16 faders to the left of the center section and 16 faders on the right.
How does the D Control know where to put the CFs when you enter CF mode?? You tell it of course. Either all the way to the left, to the left of the center section, to the right of the center section, or all the way to the right. Make sense?
www.drewmazurek.com
Old 10-28-2007, 03:46 AM
Still confused... I have a 32 channel D-Control, 16 faders on either side of the master control section. With the RCF set to Center Right (for example) what should happen? I thought it would put my 8 CF bank in the first bank to the right of the master but it doesn't. The bank stays on the far right set of faders. Only when I choose Left does anything change... placing the CF bank on the far left section of faders... which makes sense but seems counter intuitive and overly complicated since I can go in and set the LCF to Right. Now that's very confusing because the left CF bank opens when I push the RIGHT button and the right CF opens when I choose the LEFT button.
Old 10-28-2007, 05:47 AM
Do you have them declared in the right order in the Peripherals setup?
www.drewmazurek.com
Old 11-04-2007, 05:02 AM
That's what is confusing me the most... how should that be setup?
Old 11-05-2007, 12:17 PM
raal raal is offline
i believe they have to be declared in the same order as they are set up. i.e. left fader bank, center section, right fader bank.
CUSTOM FADERS JUSTIFICATION Please Help. fermez ICON & C|24 4 07-15-2012 08:37 AM
Speakerphone 2 and Custom faders Stig Eliassen Post - Surround - Video 1 07-27-2010 11:28 AM
Custom Faders moves position of all other faders!?! freeBase ICON & C|24 5 02-26-2009 06:44 PM
flipping custom faders tomlowd ICON & C|24 3 01-29-2008 04:41 PM
Have you guys been using custom faders? Igotsoul4u ICON & C|24 5 12-22-2004 05:23 AM
