Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 12-11-2018, 04:29 AM
skiffle skiffle is offline
Default MIDI Controllers won't let me select ProjectMix
Hi, I am working with Protools MP9, ProjectMix I/O and Macbook Pro 10.6.8
I have lost connection between PM and PT.
According to the PM Manual i must do the following:
With the ProjectMix I/O in Pro Tools mode, launch Pro Tools and select Hardware Setup > Peripherals > MIDI Controllers. Under Type, select HUI. Under Receive From, select ProjectMix I/O Control. Under Send To, select ProjectMix I/O Control.
My problem is that 'Midi Controllers' will Not let me select anything other than 'None' Can anybody please help me with this?
Somebody on here had the same ProjectMix Protools connection problem i'm struggling with, and filling in the Midi Controllers as above fixed the problem!
Why can't i select anything in MIDI Controllers? Please Help!!
Thanks again,
skiffle
Old 12-17-2018, 11:54 AM
Default Re: MIDI Controllers won't let me select ProjectMix
Surely somebody out there can tell me why MIDI Controllers won't let me select ProjectMix or anything else ??????
Cheers,
skiffle
Old 04-26-2019, 02:43 PM
What's the goal here? If its to use the PM as controller and audio interface("audio engine"), then AFAIK, nothing needs to be set under midi, but the PM must be selected under the HARDWARE menu as the "audio engine".
It might be worth some searching on youtube as well.
Midi Controllers will not let me select Projectmix skiffle Pro Tools M-Powered (Mac) 1 12-07-2018 12:09 PM
Not seeing MIDI controller (Akai MPK249) under Peripherals > MIDI Controllers Focuret Pro Tools 12 0 05-18-2017 12:22 PM
Midi Predifined options in Peripherals\Midi Controllers menu RuffinMedia macOS 3 03-04-2015 05:54 PM
Projectmix/Pro Tools/Select a region. yamahadrums macOS 0 03-02-2012 02:45 PM
ProjectMix - Doesn't appear in "Midi Controllers" milet22 Pro Tools M-Powered (Mac) 1 02-14-2007 04:19 PM
