Old 11-27-2019, 03:25 AM
Topophone Topophone is offline
Default MC mix not showing
Hello everybody
I'm trying to use my old mcmix, but it doesn't show in the eucon app.
-latest eucontrol software installed (with the clean uninstall beforehand)
-plugged by ethernet cable directly. (used to work that way
-ethernet 1 "connected"
-same ip address in system preferences/network and on the mc mix (error message ensues)
-eucontrol enabled in system preferences/ security/accessability
(-eucontrol enabled in protools...)
-surface powered on before computer
what am i doing wrong ?!
thank you for your help !!
i'm on high sierra os.
Old 11-28-2019, 06:54 PM
EddieJones's Avatar
Default Re: MC mix not showing
Same IP address ? Do you really mean that as it wont work?
Old 11-29-2019, 05:26 AM
THanks for the answer !
Yes
i mean,
as it was not showing, i fixed manually an ip adress on the mc mix (by holding the 2 "page" buttons while powering on), an put the same in the network preferences for ethernet1.
and yes, it wont work, at all.
Old 11-29-2019, 06:52 AM
EddieJones's Avatar
It won't. You need different addresses. Make the last number different or don't used fixed addresses at all put it back to DHCP on both.
PT 12 and BFD 3 -not showing up jroither Pro Tools 12 5 09-29-2015 04:14 PM
003 not showing up Grant26 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-14-2012 03:45 PM
003 Not showing up in AMS w/ PT9? soundboy35 macOS 3 01-08-2011 12:44 AM
What Should an 888/24 Be Showing? bradjacob Pro Tools TDM Systems (Mac) 1 10-22-2008 09:00 PM
3rd 192 not showing up deerock Pro Tools TDM Systems (Mac) 6 03-24-2002 10:27 PM
