Old 11-04-2019, 12:29 PM
Kapellmeister Kapellmeister is offline
Default Re: Logic Pro and Cubase/Nuendo top 5 bugs or Feature additions
Thank you, Eddie, for letting us participate.
Cubase Pro 10
1. It's been said before, but it is most important - Track Visibility doesn't work.
That means hiding channels on the surface is impossible. This feature would enable VCA Spill automatically! In Cubase this is triggered by a command that "shows all channels associated to selected track".
2. There is no visual feedback from the EQ (curve) and the compressor (gain reduction), in the Pro Tools Control app. I think the integrated Cubase Channel Strip should give some feedback.
3. It would be awesome if Eucon would follow the most recent clicked DAW areas. (Plugin windows, etc.)
Old 11-06-2019, 03:22 PM
mattrixx mattrixx is online now
Just remembered another one with Logic ProX.
When configuring a Send Destination with the Control App, only outputs 1 - 7 are available. No option to page through to see more output or buss options. (however, you can do it on the S3 sends config)
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 11-07-2019, 05:28 AM
MNI MNI is offline
As I mentioned in a different thread, in Cubase 10 on Mac Using the Artist Mix:
- Solo buttons won't solo the track (or light up when soloing in Cubase)
- Mute buttons won't work on VCA tracks (and won't show as muted when muting in Cubase).
Also, a while ago using the PT | Control app, it would crash when I had too many tracks in my session, causing Eucon to crash, cuasing Cubase to crash.
Hope this helps!
Old 11-07-2019, 08:19 AM
Funkybot Funkybot is offline
Using Cubase 10.0.50 and Windows 10, my big one is the track visibility not staying in sync between Cubase and the Artist Mix. Example: I hide several tracks in the Cubase mixer, the Artist Mix continues to show them.
I'm on Windows, using an Artist Mix and Solo on the Artist Mix = Listen on the Cubase track. Which I'm fine with, since that's what I usually want. Does it just not do anything on Mac?
Same behavior on Windows. Solo works (in that Solo=Listen like stated above).
Old 11-07-2019, 08:31 AM
MNI MNI is offline
So on Midi tracks it works as exprected (Solos that tracks I click), on all te rest (Audio, VCA, sampler tracks, Instrument, Output etc) the buttons turns red but nothing is soloed.
  #16
Old 11-07-2019, 09:35 AM
Sounds like it's Mac specific. Works on Windows. At least over here.
  #17
Old 11-07-2019, 01:53 PM
Big Mother Big Mother is offline
On Mac, seeing Artist Mix solo and mutes working as expected on Audio tracks in Cubase.
-Can confirm Mute button on VCA not functioning as MNI stated above
PT 2023.12 / Mac Mini M1 16gb SSD / OS X 14.2 / UA Apollo
  #18
Old 11-07-2019, 02:57 PM
J-S-Q J-S-Q is offline
FYI, there is a preference setting within Eucontrol that dictates whether the Solo button will activate 'Listen' or 'Solo' in Cubase.
  #19
Old 11-07-2019, 02:59 PM
This is also what I see on Windows.
  #20
Old 11-08-2019, 06:33 AM
Another improvement I'd like to see with Cubase/Eucon:
On the channel Input section (that controls Hi Cut/Low Cut/Phase/Gain etc.) when we make changes in the Remote Control Editor, they are not reflected in what we see on the control surface. Please can this be rectified?
C24 w/ Cubase/Nuendo? mike841 ICON & C|24 6 05-13-2018 05:04 PM
Anyone using S6 with Cubase and/or Nuendo ? vudoo Avid S4/S6 4 09-22-2015 10:26 AM
XMLs (Appsets) for Logic Pro X, Cubase, and Nuendo on Mac now available Kyle Splittgerber Avid S1, S3, Dock and Control App 0 05-18-2015 10:37 AM
DIGI 001 ,NUENDO ,CUBASE ,OR LOGIC geechie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-04-2002 04:06 AM
