AAE error 35
Hey, I have searched the forum AND googled, but to no avail.
I am getting mixes from a friend. Whenever I try to play the session, I get "AAE error 35". I have "saved a copy" to various internal session drives. I have batch renamed the files. I have checked and there doesn't seem to be any weird characters in the files names. Please advice!
MAC PRO 12-CORE, 64 GB RAM OSX 10.12.6 PRO TOOLS 2018.4 LOGIC 10.4.2 Last edited by oscar_wonderboy; 10-13-2018 at 02:15 AM. Reason: added jpegs |
Re: AAE error 35
Do you use iCloud Drive?
Maybe try the classic PT Prefs Here's an answer from Avid about AAE 35: "AAE 35 errors are commonly seen on systems that has a drive with the same name mounted or drives that has illegal characters on it. Renaming or dismounting one of the drives will solve this problem. Best Regards, Jim AVID Audio" |
Re: AAE error 35
Ah yes! I actually have 2 drives named "AUDIO". Didn't realize that could be the problem.... Thanks!
MAC PRO 12-CORE, 64 GB RAM OSX 10.12.6 PRO TOOLS 2018.4 LOGIC 10.4.2 |
Re: AAE error 35
Just encountered this error and it was being caused by the Noiiz Player Plugin. I just removed that one plugin and the error was resolved.
David Hughes Sound Designer shineonstudio.com Mac Pro 2 x 2.4GHz Quad Core Intel Xeon, 14GB 1066 MHz DDR3, Avid OMNI HD (Rev A), Digidesign 192, Pro Tools HD v. 10.3.9 |
Re: AAE error 35
My copy of ProTools stopped launching. I deleted ProTools and then downloaded once more. Now, when I try to play files I get this error. I'm not sure what drives might be duplicates, or to be frank, what exactly this means. Would anybody have any step by step instructions of how to proceed or what to check? Thanks! |
Re: AAE error 35
I think it's best if you start a new thread about this, in the apropriate section of the forum. Whether it's PT First, PT on mac or Windows, legacy etc. And please provide as much detail as you can about your equipment, and exactly what you did and what you experienced when the problem started. Have a look here: Help Us Help You
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Pro Tools 11 activation error-licensing service not running error message | Seismic Sound | Windows | 5 | 03-23-2015 05:35 AM |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 | Karma180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2011 07:46 PM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
