Timecode entry suddenly had +1h offset, Hickup/Bug?
Hey folks,
last friday I had a recording session, very simple just 3-4 vo tracks, 2 stereo playback and MJPEG-A video. Suddenly TC entry (* num pad) - which I constantly use - started adding 1 hour to all my entries. thus: 01452309 -> 02:45:23:09 A complete restart (OS&hardware) fixed it. Any ideas?
http://felixrost.de |
Re: Timecode entry suddenly had +1h offset, Hickup/Bug?
Hi Felix
There is a bug with the timecode counter which I demonstrated to DIGi UK way back in pt 6.4 where if you use an offset (i.e a plus or a minus to go to a relative offset ) and mis-type it can get its knickers in a twist and be 10 hours out of sync! I will try and found out the exact keystrokes required to upset it. Maybe you did something similar? The solution to avoid a reboot if you are using the big counter (as I do - being somewhat myopic) is to bring up the transport window and use the counter there instead (or vice a versa). kind regards
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
What Mike says. There is a bug in all recent versions, intermittent, although I don't think it adds an exact hour, here it tries to locate to the end of the timeline. For me it happens only after using audiosuite. I also think it might be caused only by pitch/time operations, but I am less certain of that. What I know is that it never happens when I am only mixing. It happens very regularly when I am doing serious editing, but not predictably. My workaround is to enter times into the smaller IN window until I can quit and relaunch PT. Here, I cannot just relaunch PT, haven't been able to do that for years because the MIDI driver breaks once PT closes, so a system restart is required in order to relaunch. It is a very annoying bug, but until someone can figure out exactly what causes it, a fix seems unlikely.
Yup, this bug happens to me a few times a week. It seems that if you hit "=" enter a TC location, and then change your mind by not hitting "enter" and continue working in the Edit window, that the next time you actually commit to a TC location, the weird offset is added. No way to use that window again until an app relaunch.
By the way, I too have seen this behavior since 6.x. Best, Nathaniel Reichman |
Thanks for your responses.
entering into the big counter on the transport window still did give me +1h, didn't try the small "start" field. And it did always add exactly 1 hour. I'm (luckily) not able to reproduce this bug. It has only happend once. I was not using audiosuite or elastic in that session, not even on that prog launch. btw, I have always used num pad* for entering tc positions (right next down key from the eject button on my keyboard). I just noticed num pad = does the same (under volume louder)
Timecode entry zeroes remaining digits pref | Burmansound | Pro Tools 9 | 3 | 03-03-2014 01:35 PM |
How can PT show a Timecode offset ? | Hanswurstlsepp | Pro Tools 10 | 5 | 07-05-2012 04:55 AM |
* key and timecode offset | CCash | Post - Surround - Video | 13 | 09-01-2011 01:24 PM |
PT 7.1cs7 bug? Timecode offset | audioposttvtwono | Post - Surround - Video | 5 | 06-13-2006 10:30 AM |
Timecode offset | russman | Tips & Tricks | 0 | 05-30-2001 10:08 AM |
