Old 07-03-2008, 05:14 AM
Paul PT Paul PT is offline
Default 7.4.2 LE AIR products drop-out (Polyphony?)
Hi guys,
I have a 17"Mac Book Pro 2.6GHz with 2GB RAM - Running 7.4.2 Using the AIR instruments with the M-Audio Axiom.
I seem to have a problem with polyphony... When I hold more than 4 or 5 notes down at the same time using - for eg a patch in Hybrid - the notes cut out. The more notes I hold - the worse the problem.
I sometimes get a window suggesting that I should change the buffer size etc - but the computer is running at the optomem speeds - and it is a powerfull computer. (I have changed the settings but get the same probs)
This problem happens with only 1 active instrument and midi track with no plug-ins.
Can anyone help please?
Polyphony wgouldsby macOS 2 12-22-2011 05:04 PM
Avid to drop prices on products!? M-ManLA General Discussion 17 08-31-2011 11:19 AM
7.4.2 AIR products drop-out (Polyphony?) Paul PT Tips & Tricks 0 07-03-2008 05:13 AM
MIDI Polyphony Room24Prod MIDI 2 01-27-2005 07:27 AM
SampleTank SE Polyphony AllThingsMusicStudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-10-2004 11:33 PM
