Error message:Pro Tools Hardwear it not installed or is used
What would be causing this on the following system:
Mac G4 PCI 450mhz Digi 001 PTLE 5.1 OS 9.1 Hardware not installed: could be a bad card or bad pci bus/slot. The card was just removed and was working in another computer. Hardware in use: No other apps are running. Any ideas? Thanks |
Re: Error message:Pro Tools Hardwear it not installed or is
I'm not sure if my problem is (was) "exactly" the same as yours...
For what seems like a couple of years, every time I would launch Pro Tools (MBOX), it would pop up a warning that said the hardware was in use, etc... All I could think was WTF?? Then, one day, I just reached behind the MBOX and unplugged the USB cable, and plugged it back in. Problem solved. Every single time I launched PT, I had to do that. Then, one update or another, that went away. I can't tell you which one, (there have been so many) but it went away. Does that help? john |
Error Message- Can not be imported because QuickTime is not installed | Franki123 | Getting Started | 6 | 02-12-2014 01:14 AM |
Installed Pro-Tools M-Powered, now I get this error when I try to run it... | joecalv | Pro Tools M-Powered (Win) | 1 | 08-20-2010 07:48 AM |
Error message: Pro tools hardware is either not installed or in use!! | Heaven | Pro Tools TDM Systems (Mac) | 8 | 06-11-2003 03:58 PM |
PT 5.3.1... Help me...!!! I´ve installed but there is a error message...!!! | Renan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-27-2002 10:59 AM |
Hardware not installed message | mghill1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-27-2001 08:12 AM |
