Old 03-20-2013, 11:02 AM
hattom hattom is offline
Default Some plug-in is not present on win 8
Hi
After install ProTools 10.3.4 with Win 8
its work but some plug-in is not present
BF-76
Dyn3 Compressor/Limiter
EQ3 7-Band
Extra Long Delay II
and more ....
so how can i fix it ?
need help plz
Thank You
Regards
Old 03-20-2013, 07:10 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Some plug-in is not present on win 8
Windows 8 is not qualified for Pro Tools 10 - needs to be Windows 7. You might search the forums and see if someone else has had the same issue. Some people have found workarounds to get PT 10 to work in Windows 8.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 03-20-2013, 07:25 PM
sunburst79 sunburst79 is offline
The II series plugs have been unsupported since version 7.0 or so. They should be in your unused plugins folder. They are not going to work in PT11 so I would just leave them there and use something else.
The installer will also move plugs that are incompatible there. So you should go the the plugins web page and download the latest version. Truthfully you should do that with every plug you own after a upgrade. At least check the versions numbers.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Video Window says "No Movie Present" when a video is present SoundBedouin Pro Tools M-Powered (Win) 6 03-10-2011 08:37 AM
No Movie Present boove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 01-31-2011 05:42 PM
Plug ins for slight analog distortion in the mix?? Factory present :) Patill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 08-19-2009 07:20 AM
Plug In automation parameters not present wcampbelliii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-12-2007 07:16 AM
"Plug-In is not present in the Plug-Ins folder" guestroomsound Tips & Tricks 4 09-01-2004 01:24 AM
