Old 05-27-2003, 05:02 AM
MilesD MilesD is offline
Default PT 6.01 Crashes on every launch!
I've just installed PT 6.01 and OSX, also Core Audio on my G4. I also added a lot of RAM - an additional half a gig.
And every time I try to launch PT, it hangs up on 'Midi SetUp' and then crashes. If I do a couple of restarts, it'll eventually launch.
I thought it might have to do with Core Audio, since the install notes indicate it will not work with Midi. So I pulled it out of the Audio Plugins library, but it's still crashing.
I also turned off 'Digidesign' in the Sounds prefs. Still crashing.
Any help or ideas would be GREATLY appreciated.
Thanks,
DM
Old 05-27-2003, 05:20 AM
Facts4U Facts4U is offline
Default Re: PT 6.01 Crashes on every launch!
I've got the same problem without Core Audio (G4 MDD 1,25, MBox).
If I trash the Prefs-Folder I can start ProTools LE 6.0.1 once without crashing. The next time it will hang up again when "Setting up MIDI".
Old 05-27-2003, 06:43 AM
dkrz dkrz is offline
Make sure Classic is not set to auto launch on startup or running in the backround. Make sure sleep setting is set to never and that automatic software update is turned off.
You will also have big problems if ALL your audio drives are not reformatted (HFS+) with the OSX Apple Disc utility prior to using PT6 - OSX [even if they have already been formatted as such before]
dk
www.dpksound.com
Old 05-27-2003, 11:46 AM
Thanks for the tips, dk.
Do you know if running the HFS+ drive updater going to effect my older OS9 files that I have on my firewire drive?
I've got a lot of stuff there I can't afford to lose.
dm
10.3.3 crashes on launch gtomassetti macOS 14 12-23-2012 03:49 PM
PT9 crashes on launch Jperkins macOS 0 06-25-2012 10:48 AM
PT 8 crashes on launch mylar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-29-2009 11:37 AM
PT8 Crashes on launch sonicapg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-12-2009 08:06 AM
G5 crashes on launch oi41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-11-2004 12:36 PM
