Old 01-02-2015, 11:38 AM
soapfoot soapfoot is offline
Default Re: 003 Rack Plus/ Mavericks Kernel_Task issue...please help
Just a little update-- I went back to version 10 of the 003 drivers, and now I can run Pro Tools 11 on my 002r using Yosemite without the extensive kernel_task freakout. It still might not be 100% normal-- there still seems to be as high as a 60% kernel_task spike at times, but not enough to cause Pro Tools to hang in the session I was working on this morning. Perhaps not a total fix, but a definite improvement.
Old 01-02-2015, 12:41 PM
spoke too soon... back up to its old tricks again. Quicktime seems to really make it mad.
Old 01-29-2015, 05:04 PM
ajmalott ajmalott is offline
Experiencing this as well after upgrade to 10.10.2 Yosemite. Temps idling at high 90s (C) with PT open (10.3.9 or 11.3) no session loaded. No issues whatsoever with 003 Rack powered off and built-in output as playback engine.
Hoping for a fix soon. Have to restore Mountain Lion system drive clone to get anything done right now.
Old 03-28-2015, 01:56 AM
dsetto dsetto is offline
How is this 003 current OS/current PT issue faring these days?
Old 05-24-2015, 10:50 AM
Pasz Pasz is offline
Default
Using Pro Tools 12 on Yosemite with a 003R and the kernel_task problem is still here. Please, someone at Avid let us know how to fix this.
I'm using a 24" iMac C2D + 4gb ram + Snow Leopard + Pro Tools 9 + Digi002R + Euphonix MC Control v1.
  #16
Old 09-28-2015, 01:33 PM
Brian in Charlotte Brian in Charlotte is offline
Pasz, just wondering if you ever got an answer to the Kernal_Task going through the roof? I'm on an iMac5k 10.10.4, PT 12.2 w/003R. Avid said the "Pro Tools Quicktime Server" issue was still in the process of being fixed and they are waiting on Apple. All I know is, when CPU % for Kernal_Task is well over 100%, all I have to do is shut down PT and it will calm down and fan turns off. I've tried Force Quitting the Quicktime Server and it doesn't do much for reducing the Kernal_Task.
The Voice of Brian
Mac Studio M1 Max, Focusrite Clarett2Pre, Sennheiser 416, sometimes Beta Tester for iZotope
  #17
Old 11-11-2015, 09:22 AM
UPDATE: While I'm on Yosemite, as mentioned, I have the Kernal_Task through the roof when PT 12 is running. This all started when I got a new system and it came with Yosemite. I spent many sessions with AVID tech and on the last test session, we found the 003R to be the issue. When we turn the 003R off and fire up PT the Kernal_Task it no issue. I have latest drives from Dec. 2014 but no help. They said the Pro Tools Quicktime Server issues is an Apple thing which is supposed to be fixed at some point. So, I'm gonna move away from the 003R with BLA Tweaked Mod......selling it and get another interface.
The Voice of Brian
  #18
Old 11-15-2015, 11:09 AM
KV626's Avatar
KV626 KV626 is offline
That's weird because the Pro Tools Quicktime Server is never responding in the Activity Monitor anyway, regardless of the interface used...So is it really an Apple thing? When using my SSL or 896, PTQS is always red in Activity Monitor, but kernel_task is behaving normally - with my 003R+, like you said, through the roof...
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
  #19
Old 12-01-2015, 06:44 PM
Starcrash Starcrash is offline
I'm having this issue as well. My home studio system is an 003 console, Yosemite, PT12HD, latest (well, almost a year old) 003 drivers. Kernel_task hovers around 70-85% and video engine causes intermittent CPU spikes over 100%.
Any hope for updated drivers or better performance in El Capitan or are we just hosed? I still like my 003 a lot more than what is currently available.
Pascal Garneau | IMDb
  #20
Old 12-01-2015, 07:42 PM
After much work to get this resolved it finally became apparent that the 003R is the issue and needs to be replaced. So the new Focusrite Clarett should be here Friday!!
The Voice of Brian
ISSUE: Eleven Rack + OS X Mavericks + NO Pro Tools patzivota Eleven Rack 5 04-07-2014 12:20 AM
Is it possible to run PT10 with Digi003 rack under osx 10.9 mavericks ? Nonolepiano macOS 2 03-26-2014 03:15 PM
Pro Tools 10 on Mavericks Graphics/Retina issue Brytestar macOS 6 12-05-2013 03:58 PM
Eleven Rack, PT, and Mavericks ? ducmike Eleven Rack 7 12-01-2013 10:01 PM
