#21
Re: 6085 im sick of it !!! Pt8 - sys report inside !!!
Ok what I found so far thanks to a thread at KVR going more into detail on this system and firewire chip. The firewire chipset is TI7402 (1-4pin; IEEE1394a; TI7402) the TI stands for texas instruments I guess, the original drivers that were included are TI drivers for the FW and for the mobo it's intel chipset. cheers |
#22
The TI chip should be ok.
I suggest running the DPC latency checker and the RattV3 tool to check if there are any drivers that cause this.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
#23
I just downloaded the RattV3 tool and going to install it right away. cheers |
#24
With the DPC latency checker on I get error 9094 first followed by the 6085 the 9094 again and 6085 again. only on the 6085 i get a spike in the DPC latency checker of 976µs. I can't figure out the RATT tool log though, looks gibberish to me.
#25
You have to open it in Wordpad, Notepad cannot show the format of the log correctly.
#26
I am having the same problem! I have a MACBOOK Dual Quad Pro, Protools 8, and MBOX 2. My only input is a Roland Fantom S Keyboard. 90% of the time when I try to select record to bounce tracks over from my keyboard and get a loud screeching distortion sound with the meters hitting red.... ALSO, the 10% times when there is no distortion I get the following error messages when I try to bounce the audio tracks via midi (using the keyboard as the"slave".
DAE ERROR 9131 encounter and 9060!! I purchased this MACBOOK and Pro Tools 8 2 months ago and have yet to sucessufully bounce over a track!! I did not have any of these problems when I had protools 7.3 and a PC!!!!! Any help would be greatly appreciated! |
#27
Fedarell, it would be better to start your own thread. The answers that may work for Nish probably won't work for you, especially since he's on a PC and you're on a MAC.
And to that end, it would probably serve you well to post in the MAC forum. |
#28
Not sure what I'm supposed the get out the Ratt log though but here is one, I started logging after I opened a session for a couple minutes and had 6 errors 6085 then closed the session. Errors happen frequently after I had the first one. When I open a session and press playback I'm fine to play through the song, but as soon I do a fader move or a zoom soon after thatI get the first error, then it happens all the time during playback without doing any moves.
Here's the log, cheers (oops I have to spread it over two posts) -------------------------------------------------------------------------------- | Counts by driver for: ***-*** | | From: FRI AUG-14-2009 11:56:50.22 | To: FRI AUG-14-2009 11:58:39.05 | Runs: 2 -------------------------------------------------------------------------------- Cumulative Histogram for: dpclat_driver.sys (\??\C:\WINDOWS\system32\drivers\dpclat_driver.sys ) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 2, 2.00us to 2.99us, <3.00us, 0, 0, 23339 3, 3.00us to 3.99us, <4.00us, 0, 0, 162326 4, 4.00us to 4.99us, <5.00us, 0, 0, 57963 5, 5.00us to 5.99us, <6.00us, 0, 0, 21493 6, 6.00us to 6.99us, <7.00us, 0, 0, 4961 7, 7.00us to 7.99us, <8.00us, 0, 0, 5938 8, 8.00us to 8.99us, <9.00us, 0, 0, 2945 9, 9.00us to 9.99us, <10.00us, 0, 0, 1049 10, 10.00us to 19.99us, <20.00us, 0, 0, 882 11, 20.00us to 29.99us, <30.00us, 0, 0, 7 12, 30.00us to 39.99us, <40.00us, 0, 0, 1 16, 70.00us to 79.99us, <80.00us, 0, 0, 1 TOTALS, 0, 0, 280905 Cumulative Histogram for: afd.sys (\SystemRoot\System32\drivers\afd.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 0, 0, 4 2, 2.00us to 2.99us, <3.00us, 0, 0, 16 3, 3.00us to 3.99us, <4.00us, 0, 0, 75 4, 4.00us to 4.99us, <5.00us, 0, 0, 127 5, 5.00us to 5.99us, <6.00us, 0, 0, 314 6, 6.00us to 6.99us, <7.00us, 0, 0, 187 7, 7.00us to 7.99us, <8.00us, 0, 0, 52 8, 8.00us to 8.99us, <9.00us, 0, 0, 28 9, 9.00us to 9.99us, <10.00us, 0, 0, 8 10, 10.00us to 19.99us, <20.00us, 0, 0, 22 11, 20.00us to 29.99us, <30.00us, 0, 0, 1 TOTALS, 0, 0, 834 Cumulative Histogram for: HDAudBus.sys (\SystemRoot\system32\DRIVERS\HDAudBus.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 111, 0, 0 2, 2.00us to 2.99us, <3.00us, 345, 97, 0 3, 3.00us to 3.99us, <4.00us, 129, 697, 0 4, 4.00us to 4.99us, <5.00us, 762, 332, 0 5, 5.00us to 5.99us, <6.00us, 462, 258, 0 6, 6.00us to 6.99us, <7.00us, 214, 90, 0 7, 7.00us to 7.99us, <8.00us, 73, 33, 0 8, 8.00us to 8.99us, <9.00us, 40, 45, 0 9, 9.00us to 9.99us, <10.00us, 12, 53, 0 10, 10.00us to 19.99us, <20.00us, 33, 41, 0 11, 20.00us to 29.99us, <30.00us, 2, 1, 0 TOTALS, 2183, 1647, 0 Cumulative Histogram for: i8042prt.sys (\SystemRoot\system32\DRIVERS\i8042prt.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 6, 6.00us to 6.99us, <7.00us, 5, 0, 0 7, 7.00us to 7.99us, <8.00us, 1, 0, 0 10, 10.00us to 19.99us, <20.00us, 0, 6, 0 TOTALS, 6, 6, 0 Cumulative Histogram for: ipnat.sys (\SystemRoot\system32\DRIVERS\ipnat.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 7, 7.00us to 7.99us, <8.00us, 0, 0, 1 8, 8.00us to 8.99us, <9.00us, 0, 0, 4 TOTALS, 0, 0, 5 Cumulative Histogram for: ipsec.sys (\SystemRoot\system32\DRIVERS\ipsec.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 0, 0, 4 2, 2.00us to 2.99us, <3.00us, 0, 0, 4 3, 3.00us to 3.99us, <4.00us, 0, 0, 2 TOTALS, 0, 0, 10 Cumulative Histogram for: rdbss.sys (\SystemRoot\system32\DRIVERS\rdbss.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 0, 0, 609 2, 2.00us to 2.99us, <3.00us, 0, 0, 2305 3, 3.00us to 3.99us, <4.00us, 0, 0, 1556 4, 4.00us to 4.99us, <5.00us, 0, 0, 195 5, 5.00us to 5.99us, <6.00us, 0, 0, 92 6, 6.00us to 6.99us, <7.00us, 0, 0, 46 7, 7.00us to 7.99us, <8.00us, 0, 0, 112 8, 8.00us to 8.99us, <9.00us, 0, 0, 8 9, 9.00us to 9.99us, <10.00us, 0, 0, 2 10, 10.00us to 19.99us, <20.00us, 0, 0, 6 TOTALS, 0, 0, 4931 Cumulative Histogram for: RtkHDAud.sys (\SystemRoot\system32\drivers\RtkHDAud.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 3, 3.00us to 3.99us, <4.00us, 0, 0, 19 4, 4.00us to 4.99us, <5.00us, 0, 0, 134 5, 5.00us to 5.99us, <6.00us, 0, 0, 208 6, 6.00us to 6.99us, <7.00us, 0, 0, 94 7, 7.00us to 7.99us, <8.00us, 0, 0, 32 8, 8.00us to 8.99us, <9.00us, 0, 0, 25 9, 9.00us to 9.99us, <10.00us, 0, 0, 8 10, 10.00us to 19.99us, <20.00us, 0, 0, 29 TOTALS, 0, 0, 549 Cumulative Histogram for: sdbus.sys (\SystemRoot\system32\DRIVERS\sdbus.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 335, 0, 0 2, 2.00us to 2.99us, <3.00us, 1536, 0, 0 3, 3.00us to 3.99us, <4.00us, 5324, 0, 0 4, 4.00us to 4.99us, <5.00us, 1505, 0, 0 5, 5.00us to 5.99us, <6.00us, 440, 0, 0 6, 6.00us to 6.99us, <7.00us, 132, 0, 0 7, 7.00us to 7.99us, <8.00us, 33, 0, 0 8, 8.00us to 8.99us, <9.00us, 31, 0, 0 9, 9.00us to 9.99us, <10.00us, 13, 0, 0 10, 10.00us to 19.99us, <20.00us, 19, 0, 0 11, 20.00us to 29.99us, <30.00us, 1, 0, 0 TOTALS, 9369, 0, 0 Cumulative Histogram for: tcpip.sys (\SystemRoot\system32\DRIVERS\tcpip.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 0, 2, 0 2, 2.00us to 2.99us, <3.00us, 0, 610, 0 3, 3.00us to 3.99us, <4.00us, 0, 3160, 0 4, 4.00us to 4.99us, <5.00us, 0, 2056, 0 5, 5.00us to 5.99us, <6.00us, 0, 2311, 0 6, 6.00us to 6.99us, <7.00us, 0, 1449, 0 7, 7.00us to 7.99us, <8.00us, 0, 631, 0 8, 8.00us to 8.99us, <9.00us, 0, 374, 0 9, 9.00us to 9.99us, <10.00us, 0, 135, 0 10, 10.00us to 19.99us, <20.00us, 0, 188, 0 TOTALS, 0, 10916, 0 Cumulative Histogram for: TDI.SYS (\SystemRoot\system32\DRIVERS\TDI.SYS) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 2, 2.00us to 2.99us, <3.00us, 0, 0, 15 3, 3.00us to 3.99us, <4.00us, 0, 0, 82 4, 4.00us to 4.99us, <5.00us, 0, 0, 167 5, 5.00us to 5.99us, <6.00us, 0, 0, 205 6, 6.00us to 6.99us, <7.00us, 0, 0, 77 7, 7.00us to 7.99us, <8.00us, 0, 0, 23 8, 8.00us to 8.99us, <9.00us, 0, 0, 17 9, 9.00us to 9.99us, <10.00us, 0, 0, 8 10, 10.00us to 19.99us, <20.00us, 0, 0, 10 TOTALS, 0, 0, 604 Cumulative Histogram for: tifm21.sys (\SystemRoot\system32\drivers\tifm21.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 2, 2.00us to 2.99us, <3.00us, 182, 0, 0 3, 3.00us to 3.99us, <4.00us, 69, 0, 0 4, 4.00us to 4.99us, <5.00us, 12, 0, 0 5, 5.00us to 5.99us, <6.00us, 2, 0, 0 6, 6.00us to 6.99us, <7.00us, 1, 0, 0 7, 7.00us to 7.99us, <8.00us, 1, 0, 0 8, 8.00us to 8.99us, <9.00us, 2, 0, 0 TOTALS, 269, 0, 0 |
#29
Cumulative Histogram for: USBPORT.SYS (\SystemRoot\system32\DRIVERS\USBPORT.SYS)
#, Range, Label, ISR Count, DPC Count, DPCTmr Count 2, 2.00us to 2.99us, <3.00us, 493, 6, 0 3, 3.00us to 3.99us, <4.00us, 1169, 5017, 0 4, 4.00us to 4.99us, <5.00us, 902, 2545, 0 5, 5.00us to 5.99us, <6.00us, 1687, 1763, 0 6, 6.00us to 6.99us, <7.00us, 3496, 733, 3 7, 7.00us to 7.99us, <8.00us, 2759, 202, 30 8, 8.00us to 8.99us, <9.00us, 1813, 217, 85 9, 9.00us to 9.99us, <10.00us, 704, 122, 89 10, 10.00us to 19.99us, <20.00us, 937, 205, 2539 11, 20.00us to 29.99us, <30.00us, 6, 159, 903 12, 30.00us to 39.99us, <40.00us, 0, 123, 70 13, 40.00us to 49.99us, <50.00us, 0, 668, 7 14, 50.00us to 59.99us, <60.00us, 0, 938, 0 15, 60.00us to 69.99us, <70.00us, 0, 2229, 0 16, 70.00us to 79.99us, <80.00us, 0, 3071, 0 17, 80.00us to 89.99us, <90.00us, 0, 1298, 0 18, 90.00us to 99.99us, <100.00us, 0, 515, 0 19, 100.00us to 109.99us, <110.00us, 0, 221, 0 20, 110.00us to 119.99us, <120.00us, 0, 73, 0 21, 120.00us to 129.99us, <130.00us, 0, 31, 0 22, 130.00us to 139.99us, <140.00us, 0, 9, 0 23, 140.00us to 149.99us, <150.00us, 0, 2, 0 24, 150.00us to 159.99us, <160.00us, 0, 2, 0 25, 160.00us to 169.99us, <170.00us, 0, 1, 0 28, 190.00us to 199.99us, <200.00us, 0, 1, 0 TOTALS, 13966, 20151, 3726 Cumulative Histogram for: VIDEOPRT.SYS (\SystemRoot\system32\DRIVERS\VIDEOPRT.SYS) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 4, 4.00us to 4.99us, <5.00us, 7, 0, 0 5, 5.00us to 5.99us, <6.00us, 4, 0, 0 6, 6.00us to 6.99us, <7.00us, 8, 0, 0 7, 7.00us to 7.99us, <8.00us, 7, 0, 0 8, 8.00us to 8.99us, <9.00us, 4, 0, 0 9, 9.00us to 9.99us, <10.00us, 5, 0, 0 10, 10.00us to 19.99us, <20.00us, 1857, 0, 0 11, 20.00us to 29.99us, <30.00us, 3223, 0, 0 12, 30.00us to 39.99us, <40.00us, 5961, 0, 0 13, 40.00us to 49.99us, <50.00us, 1249, 0, 0 14, 50.00us to 59.99us, <60.00us, 253, 8, 0 15, 60.00us to 69.99us, <70.00us, 54, 51, 0 16, 70.00us to 79.99us, <80.00us, 5, 144, 0 17, 80.00us to 89.99us, <90.00us, 0, 269, 0 18, 90.00us to 99.99us, <100.00us, 0, 62, 0 19, 100.00us to 109.99us, <110.00us, 0, 7, 0 20, 110.00us to 119.99us, <120.00us, 0, 3, 0 1010, 20.00ms to 29.99ms, <30.00ms, 0, 4, 0 1011, 30.00ms to 39.99ms, <40.00ms, 0, 1, 0 1014, 60.00ms to 69.99ms, <70.00ms, 0, 1, 0 TOTALS, 12637, 550, 0 Cumulative Histogram for: watchdog.sys (\SystemRoot\System32\watchdog.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 0, 0, 36 2, 2.00us to 2.99us, <3.00us, 0, 0, 16 3, 3.00us to 3.99us, <4.00us, 0, 0, 2 TOTALS, 0, 0, 54 Cumulative Histogram for: 1394BUS.SYS (\WINDOWS\system32\DRIVERS\1394BUS.SYS) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 3, 3.00us to 3.99us, <4.00us, 0, 3, 0 10, 10.00us to 19.99us, <20.00us, 0, 2, 0 TOTALS, 0, 5, 0 Cumulative Histogram for: ntkrnlpa.exe (\WINDOWS\system32\ntkrnlpa.exe) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 0, 0, 139 2, 2.00us to 2.99us, <3.00us, 0, 0, 339 3, 3.00us to 3.99us, <4.00us, 0, 47334, 301 4, 4.00us to 4.99us, <5.00us, 0, 66615, 72 5, 5.00us to 5.99us, <6.00us, 0, 77888, 31 6, 6.00us to 6.99us, <7.00us, 0, 41509, 6 7, 7.00us to 7.99us, <8.00us, 0, 17340, 3 8, 8.00us to 8.99us, <9.00us, 0, 11391, 1 9, 9.00us to 9.99us, <10.00us, 0, 4522, 2 10, 10.00us to 19.99us, <20.00us, 0, 14221, 2 11, 20.00us to 29.99us, <30.00us, 0, 82, 0 12, 30.00us to 39.99us, <40.00us, 0, 3, 0 14, 50.00us to 59.99us, <60.00us, 0, 0, 1 16, 70.00us to 79.99us, <80.00us, 0, 0, 2 17, 80.00us to 89.99us, <90.00us, 0, 0, 3 18, 90.00us to 99.99us, <100.00us, 0, 0, 19 19, 100.00us to 109.99us, <110.00us, 0, 0, 46 20, 110.00us to 119.99us, <120.00us, 0, 0, 86 21, 120.00us to 129.99us, <130.00us, 0, 0, 49 22, 130.00us to 139.99us, <140.00us, 0, 0, 45 23, 140.00us to 149.99us, <150.00us, 0, 0, 16 24, 150.00us to 159.99us, <160.00us, 0, 0, 6 25, 160.00us to 169.99us, <170.00us, 0, 0, 2 TOTALS, 0, 280905, 1171 Cumulative Histogram for: ACPI.sys (ACPI.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 2, 2.00us to 2.99us, <3.00us, 0, 97, 1 3, 3.00us to 3.99us, <4.00us, 0, 18, 20 4, 4.00us to 4.99us, <5.00us, 0, 3, 16 5, 5.00us to 5.99us, <6.00us, 0, 1, 13 6, 6.00us to 6.99us, <7.00us, 0, 107, 6 7, 7.00us to 7.99us, <8.00us, 0, 108, 1 8, 8.00us to 8.99us, <9.00us, 0, 42, 2 9, 9.00us to 9.99us, <10.00us, 0, 24, 1 10, 10.00us to 19.99us, <20.00us, 628, 53, 0 11, 20.00us to 29.99us, <30.00us, 9, 0, 0 12, 30.00us to 39.99us, <40.00us, 0, 123, 0 13, 40.00us to 49.99us, <50.00us, 0, 47, 0 14, 50.00us to 59.99us, <60.00us, 0, 29, 0 15, 60.00us to 69.99us, <70.00us, 0, 11, 0 16, 70.00us to 79.99us, <80.00us, 0, 9, 0 17, 80.00us to 89.99us, <90.00us, 0, 13, 0 18, 90.00us to 99.99us, <100.00us, 0, 2, 0 20, 110.00us to 119.99us, <120.00us, 0, 2, 0 21, 120.00us to 129.99us, <130.00us, 0, 1, 0 22, 130.00us to 139.99us, <140.00us, 0, 5, 0 24, 150.00us to 159.99us, <160.00us, 0, 1, 0 25, 160.00us to 169.99us, <170.00us, 0, 25, 0 26, 170.00us to 179.99us, <180.00us, 0, 20, 0 27, 180.00us to 189.99us, <190.00us, 0, 5, 0 41, 320.00us to 329.99us, <330.00us, 0, 1, 0 TOTALS, 637, 747, 60 Cumulative Histogram for: atapi.sys (atapi.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 405, 6, 0 2, 2.00us to 2.99us, <3.00us, 3117, 60, 0 3, 3.00us to 3.99us, <4.00us, 3892, 103, 0 4, 4.00us to 4.99us, <5.00us, 8384, 82, 8 5, 5.00us to 5.99us, <6.00us, 6931, 181, 7 6, 6.00us to 6.99us, <7.00us, 3644, 128, 4 7, 7.00us to 7.99us, <8.00us, 949, 112, 4 8, 8.00us to 8.99us, <9.00us, 728, 93, 0 9, 9.00us to 9.99us, <10.00us, 1199, 48, 1 10, 10.00us to 19.99us, <20.00us, 7543, 2078, 2 11, 20.00us to 29.99us, <30.00us, 495, 4329, 9 12, 30.00us to 39.99us, <40.00us, 115, 1535, 10 13, 40.00us to 49.99us, <50.00us, 167, 276, 2 14, 50.00us to 59.99us, <60.00us, 7, 72, 0 15, 60.00us to 69.99us, <70.00us, 0, 7, 0 16, 70.00us to 79.99us, <80.00us, 0, 2, 0 17, 80.00us to 89.99us, <90.00us, 0, 3, 0 19, 100.00us to 109.99us, <110.00us, 0, 1, 0 TOTALS, 37576, 9116, 47 Cumulative Histogram for: fltmgr.sys (fltmgr.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 0, 0, 5 TOTALS, 0, 0, 5 Cumulative Histogram for: NDIS.sys (NDIS.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 0, 0, 84 2, 2.00us to 2.99us, <3.00us, 0, 0, 97 3, 3.00us to 3.99us, <4.00us, 0, 0, 85 4, 4.00us to 4.99us, <5.00us, 0, 0, 7 5, 5.00us to 5.99us, <6.00us, 0, 0, 5 6, 6.00us to 6.99us, <7.00us, 0, 0, 1 TOTALS, 0, 0, 279 Cumulative Histogram for: Ntfs.sys (Ntfs.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 0, 0, 2 2, 2.00us to 2.99us, <3.00us, 0, 0, 27 3, 3.00us to 3.99us, <4.00us, 0, 0, 22 4, 4.00us to 4.99us, <5.00us, 0, 0, 2 TOTALS, 0, 0, 53 Cumulative Histogram for: ohci1394.sys (ohci1394.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 1, 1.00us to 1.99us, <2.00us, 4960, 974, 0 2, 2.00us to 2.99us, <3.00us, 4934, 475, 0 3, 3.00us to 3.99us, <4.00us, 162272, 89, 0 4, 4.00us to 4.99us, <5.00us, 173185, 22, 0 5, 5.00us to 5.99us, <6.00us, 111055, 15, 0 6, 6.00us to 6.99us, <7.00us, 49027, 15, 0 7, 7.00us to 7.99us, <8.00us, 14032, 13, 0 8, 8.00us to 8.99us, <9.00us, 6918, 116, 0 9, 9.00us to 9.99us, <10.00us, 3289, 5, 0 10, 10.00us to 19.99us, <20.00us, 7567, 405946, 0 11, 20.00us to 29.99us, <30.00us, 34, 104865, 0 12, 30.00us to 39.99us, <40.00us, 19, 13204, 0 13, 40.00us to 49.99us, <50.00us, 8, 1745, 0 14, 50.00us to 59.99us, <60.00us, 6, 178, 0 15, 60.00us to 69.99us, <70.00us, 4, 40, 0 16, 70.00us to 79.99us, <80.00us, 0, 6, 0 17, 80.00us to 89.99us, <90.00us, 1, 3, 0 18, 90.00us to 99.99us, <100.00us, 2, 2, 0 19, 100.00us to 109.99us, <110.00us, 2, 0, 0 21, 120.00us to 129.99us, <130.00us, 1, 0, 0 TOTALS, 537316, 527713, 0 Cumulative Histogram for: pcmcia.sys (pcmcia.sys) #, Range, Label, ISR Count, DPC Count, DPCTmr Count 4, 4.00us to 4.99us, <5.00us, 1708, 0, 0 5, 5.00us to 5.99us, <6.00us, 2863, 0, 0 6, 6.00us to 6.99us, <7.00us, 3499, 0, 0 7, 7.00us to 7.99us, <8.00us, 1611, 0, 0 8, 8.00us to 8.99us, <9.00us, 1177, 0, 0 9, 9.00us to 9.99us, <10.00us, 378, 0, 0 10, 10.00us to 19.99us, <20.00us, 582, 0, 0 11, 20.00us to 29.99us, <30.00us, 6, 0, 0 12, 30.00us to 39.99us, <40.00us, 1, 0, 0 TOTALS, 11825, 0, 0 |
#30
VIDEOPRT.SYS has latencies in milliseconds!
Mine has just 80 microseconds(us) Check your driver! Moreover there are some HD audio drivers running: HDAudBus.sys RtkHDAud.sys check if this is really switched off! I have a different 1394 driver running, but this depends on the system. Do you have any graphics card booster or similar utility running? Sorry if I cannot be of more help, but it may be just a small thing with your setup.
Mbox 3 Mini isn't working (report inside) | thirdpancake | Tips & Tricks | 3 | 03-03-2013 06:24 AM |
PT9 fails to play - Sandra report inside | Ignorant Me | Windows | 5 | 12-17-2011 06:46 AM |
Underflow error (6085) (w/ Sandra report) | TheEvilCow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-14-2011 07:17 PM |
PT8cs3 Win 7 64bit Random Audio Glitches (Full Report Inside) Need Help | 2InchTapeIsYourFriend | Pro Tools TDM Systems (Win) | 10 | 02-26-2010 01:39 AM |
Laptop issues, won't run PT , System report inside | Table Syrup Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 03-12-2009 10:47 AM |
