clicks in recording on all channels
I have a project that was a live recording done on someone else's system using PT 7.3 M powered. I brought it into my system (7.1 M powered) and it seems to open fine, but I have random clicks that appear on the tracks. When I zoom in they are in the same spot on all tracks and look kind of like an inverted square, larger on some tracks than others but present on all tracks. I can correct them with the pencil tool but it will take forever to correct them all. They occur maybe every 10 or 20 seconds. Is there an easy fix and any idea what caused this originally? I'm kind of a noob to PT (I'm an old analog guy), any help very much appreciated!!
Re: clicks in recording on all channels
its a clocking error, have fun with the pencil tool its the only way to fix it, and tell your friend to set the clock source on his m-audio device properly next time...
or go to..... http://www.wavearts.com/..... download their Master Restoration suite demo plugins, and see if they can clean up the problem
Okay, I had the same problem and this solution worked for me, maybe it will for you, let's see: 1) SETUP 2) PLAYBACK ENGINE 3) RTAS ENGINE - Untick box that says 'ignore Errors during playback/record (may cause clicks and pops) Problem Solved. Took me ages to sort that one out myself. JazzyJ
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
Recording Only On 2 Channels | blindside777 | Pro Tools M-Powered (Mac) | 0 | 01-10-2012 01:12 PM |
Downward "clicks" on ADAT channels | mattvivsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-22-2009 09:06 AM |
recording 8 channels at once? | seneros | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-10-2006 10:53 PM |
Recording on all eight channels on DIGI 002 | calibos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-22-2006 09:28 PM |
Recording more than 8 simultaneous channels? | scottyplayero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-29-2003 03:16 PM |
